Team Associated T5M Discussion
#2521
Super Moderator
So I purchased the ae clamping rear hex's, what false advertising that description is, I used pliers and squeezed them together and then did the screw up until there was no gap, with the hex not even mounted to the car, and it just slips on and off, how can ae sell us this junk that clearly doesn't do the job it's meant to, what's the solution do I need to stick with the plastic ones?
#2522
I also ordered the AE rear Alum. clamping hexes and one stripped out first time. I used an allen wrench not a large driver or anything like that, and it was used the long way in the bolt not the short one where you can crank it a bit more. I have been racing for better than 15 years, so it's not like this is my first build. I do know what I am doing.
#2523
Ease your storm there guy. I installed the clamping hexes on my T5M and they are great. I did not have any problems with the screws breaking or anything sliding off. Because the screw is tiny on these hexes, you need to tighten them down slowly and gently. When they feel tight, they are tight, no need to bear down on them because that is when guys break the screws and write on here that they are crap. In your case, squeezing them together defeats the purpose of the clamping hex. You have already squeezed them down so there is no clamping force to hold the hex onto the axle. How can the hex clamp to the axle surface if you already smooshed it down? By clamping them down with pliers, you most likely deformed the inside mating surface of the hex. Aluminum is soft and does not take much to deform it. I would bet the hole that the axle slides through is oblonged and hence why it is not clamping. I call user error in this case like most cases I have heard with people having problems with the aluminum clamping hexes.
#2524
Obviously I tried it that way first im not an idiot, but it just slides off and doesn't clamp down so then I removed it and clamped it all the way down just to see if it would grab but no it just slides over the axle, I will check the part number but it was bought through amain under t5m parts and compatibility was t5m.
#2527
I'm trying to get my rear locked in more tried turning down radio and went down to 25 in shock oil but still sliding out on me. I'm running m4 electrons with sauce. Any one have any ideas what other adjustments u can make in the truck? Thanks
#2528
I might buy this truck off somebody i know . I'm wondering what does it take to convert it over to a B5M buggy ?
If its just the arms, shock towers, body that's no big deal i already have 2wd Buggy tires just not the B5M front wheels.
#2529
Chassis Cradle - $8.39
Front and Rear Arms - $7.49 and $6.59
Driveshafts - $27.49
Front Axles - $8.39
Turnbuckles - $2.89 x3
Front and Rear Shock Tower - $4.79 and $5.69
Wheel Hexes - $1.89 x2
Body mounts - $3.79
Wheels - $5.39 x2
Tires - ?
Body - $25.49
$169.44 without tires and without a coupon code. Everything I listed is stock. No titanium turnbuckles. No aluminum wheel hexes or axles.
Might be better off selling your B5M and buying a T5M kit.
#2530
Chassis - $50.99
Front Axles - $8.39
Body mounts - $3.79
Wheels - $5.39 x2
Tires - ?
Body - $25.49
Front Axles - $8.39
Body mounts - $3.79
Wheels - $5.39 x2
Tires - ?
Body - $25.49
Ok thanks i dint think it was that much different .
I don't have the B5M i run a Dex210 V2.
#2532
Inserts
So heres the deal. Had one T5m that worked great, decided I wanted to give the SC5M a shot, s I sold the T5M, which I immediately replaced cause I missed my truck. Here is the problem, same exact setup, same exact tires, same exact everything that was on the old truck, and this new one drives like crap. Wont track straight during breaking, hooks around turns, is not smooth anywhere on the track. Ballcups are reasonably free (better then the old truck), I am at a total loss, the SC5M which has basically the exact same setup, (expect for grey front springs (and front/rear pistons) in so in the pocket, I threw a 6.5 in it, and it handled it like a champ. The T5M is a squirrel monster with a 13.5. I'm baffled. My build skills are good, diff is fine, bearings have been replaced with ceramics and is free as can be. At a total loss.
#2533
Turf setup?
Anyone have a good setup they are willing to share for astro turf?
