RB Engine Thread
#406
I can't remember which engine they are based from, but I think they might be Picco or Sirio based. I've only heard a little bit of information on the Xceed engines, but I did hear they are pretty good - they don't have a fanbase like Novarossi or RB, but in the right hands it can perform very well.
With the RB Touring series, on a small track you would be better getting the T10 or T11, or even a TJ## if it's a very small track, but the T10/T11 are essentially the same engines anyway, just a different head. They have the same crank and sleeve which means identical timings, so theoretically they should perform the same as each other, unless the cases are different and the crank timing has been changed, but I think they are the same.
I hope I didn't confuse you with any of this
I came back from lunch and I decided to take the PT flash! But now I'm reading your thread and became confused
Would you rather take the RB T11 as the Flash PT?
yes, the xceed ZX12 DS4 are also available as EM Edition ( Edo Modified ), so I think they are also Picco based.
hmmm, difficult to decide now...
#407
Yes, Xceed is Picco based. The Flash is excellent, you will be just fine with it.
#408
Allthough I am 1/8 fun I have seen the T11 perform and I got crazy it is a lot faster then the T10 for sure...
#409
It would really depend on where you want to race.
With either engine you can race pretty much on any track, but the Nova PT Tuned will definitely be better than the RB Touring 11 (standard) The T11RC/RS might be on the same level as the PT Tuned, but I'm not sure.
Im sure that RB is still having all of their engines made in the same place as Novarossi, only all of their heads, piston/sleeve/rod sets and cranks are made to RB specifications, not Novarossi. With either engine, you will still be happy with the performance no matter what.
Comparing the T11 and Flash PT, if they were the same price I would definitely go with the PT Tuned.
#412
Has somebody detailed photos from the RB T11 RS. I would like to see the crankshaft and piston.
Many thanks.
Many thanks.
#414
None, the crankpin of the RB is a tiny bit larger, I believe 5.0 or 5.02mm while the NR is 4.98
You can try to make the hole of a R7 rod larger with a 5mm diamond bit, I have done it once and did work fine:
#416
Can anyone help. Can CXR piston set go into CX crank case without changing the crankshalf .
#418
#419
