Kyosho Scorpion re-release
#212
ah thanks
Will search for some on evilbay
#213
Suspension binding issue
During my Tomahawk build, I finally realised the mistake I had made which caused my re-re Scorpions rear arms to bind. Having owned many of these chassis, I just simply assumed it should be built like my original one.
The two suspension shaft holders have a tapered end. The correct way to install them is: install the taller one with taper side up and the shorter one taper side down,. Its clearly shown in the manual but I overlooked it.
#216
Trader Rating: 171 (100%+)
Are those shock the stock ones or are they are the after ones
#217
stock rear is prox 1.6" diameter.
Stock front is prox 1.9" diameter.
Those looks like original plastic chrome wheels
#219
Then I think you need some wheel adapters.
