OMG PLZ HELP
OMG PLZ HELP
i was cycling my batteries and i heard a strange sound coming out of them.
it was like boiling .i dont know what is that ? i immediatly stopped it, but they are still boiling.
Sounds like they were venting. Need more info on your setup; Are your packs matched? What type of charger/amps/cutoff/etc...
i use Quadra LRP Charger no cutoff no nothing i was just doing a refresh for the batteries which is a i cycling mode. it took more than 2 hours, i thought it was good for the cells and kept them until i heard the sound.
no they are not matched
it was on 5 amps
i have puttin the battery infront of a cooling fan and there is no sound coming out.
does that mean byebye cells ?
how hot were the abtteries when they done this, was it a popping or sounded like air excaping? I had a set off cells have a boiling cells once but they soon after exploded and im sure you would have said if this happens so im geussing it isnt that
no they were not very hot and the sound came from the (+) side of the battery and the (-) side
they have probably vented, this happens sometimes usually after the cells are a bit into there life with a couple hundred cycles. Some people say that this makes the cells crap on the track but i didnt notice any difference. Just watch when you recharge them as they may false peak
well, its not 1 of the best packs i have but i try charging them carefully and try them. they might be usefull for practicing
at worst you can split them down and use as a lathe pack
Good Idea
well,, thanks guys, and sorry for any inconvenience
