Serpent 748 200mm nitro onroad kit
#394
I've used under the rollbar/handle because I usually space mine up to support the body as well, so I was going to put a spacer there, I'm just using the heim joint as the spacer.
Yes I know the next question, why space the handle up? I find the car/body suffers less damage & has a better chance of righting it's self in a roll over with the bar that high.
#395
Hey guys is it safe to use esr-971 servos for steering also. Also I prefer lipo so can someone tell me what lipo pack will fit with no problem for 748
#396
In 2014 i have seen at least 4 sanwa ers 971 that went up in smoke direct on lipo, my advice is to use a regulator or better life
#397
Ok so I see some guys here say use the reedy life packs right or exceed right? Do you know which one will fit perfect in the 748? So it is ok to run both servos for throttle ans steering?
#398
Perfect fit is the zippy700, its small, so you have an extra mass you can place in the front or rear. you win 30 a 40 gram mass and can drive a 45 min final. its on the edge for racing on the limit. The price is the only bad thing, t costs around 3 dollar.
#399
Ok thanks baker
#400
Rbakker
#401
Yes it is I cannot believe that price. To bad the better price for the esr-971 are in hong kong
#404
Ok nitro so my ? Again is do you think it is fine to run esr 971 in both steering also? Ok kyosho thanks. Which one do you use and does it fit tight.
