R1 Brushless Motors (Roar approved) 17.5,21.5 & 13.5 >
Old 04-13-2014, 10:43 AM
  #91
Originally Posted by Travis S
Has anyone figured out what timing works best in a 21.5 motor? I am currently running an orca 21.5 with 2mm past last mark and a 3.55 gear ratio. I just haven't been able to figure out this motor yet.
Same timing as you but I'm on a big outdoor asphalt track and my ORCA 21.5 FDR is 3.3 (133F with no fan) and needs to be somewhere in the 3.2 to 3.1 (range probably with a fan). Ran by mistake a 3.0 FDR and it was fast but hot (170F) and still not as fast as the fastest. Was hoping the R1 would fix that but now I'm told it's out of stock too. Just my Bad luck.
John Wallace2 is offline
Old 04-13-2014, 06:39 PM
  #92
Does anyone else's motor whine loudly compared to other brands? I don't know that it matters but it's definitely noticeable.
flapper is offline
Old 04-14-2014, 10:58 PM
  #93
R1wurks's Avatar
I got this setup from Brian R. 42* timing 3.7fdr (R1 21.5) with 8.4v fan
R1wurks is offline
Old 04-14-2014, 11:01 PM
  #94
Trader Rating: 17 (100%+)
When will the 13.5 motors be available?
Thx.
DJGonzo69 is offline
Old 04-14-2014, 11:13 PM
  #95
EDWARD2003's Avatar
R1 Motors available in Japan?
EDWARD2003 is offline
Old 04-14-2014, 11:42 PM
  #96
tobyzhang's Avatar
Trader Rating: 15 (100%+)
the rpm of R1 motor is definitely very high. The whine is noticeable upon free revving. My r1 21.5 free revs higher than my reedy sonic 17.5. But it is not as fast due to lower torque across the board. R1 is definitely a fast motor but have to gear higher compared to most other motors.
tobyzhang is offline
Old 04-15-2014, 04:41 AM
  #97
42* mark on the can? anything over the 30* mark on the can my R1 17.5 clogs real bad.
I've been running a 3.97 - 4.15 fdr with 24* timing coming off the track after 6mins with a temp of 120*. The car is quick but I feel there is more in the motor.
Indyonroad is offline
Old 04-15-2014, 09:35 AM
  #98
R/C Tech Elite Member
JayL's Avatar
Is this for a touring car or F1?
JayL is offline
Old 04-15-2014, 09:53 AM
  #99
b20btec's Avatar
Trader Rating: 11 (100%+)
Arrow
I like this motor in 17.5 TC with 3.7 28 deg. timing, also feels better with a large spur and pinion combo, instead of small spur small pinion. 100/51 in xray seems to keep it in the powerband. 88/47 felt good but the lower rpm of the 51 pinion is fantastic.
Forgot to mention, carpet indoor at rsd Houston.
b20btec is offline
Old 04-15-2014, 10:59 AM
  #100
Thanks, I'm running a 96t spur but will try the 100/51 this Friday, I'm also running Xray.
Old 04-25-2014, 12:52 AM
  #101
It's not the big spur big pinion combo that is causing the difference, you just have a different FDR than with the smaller spur and pinion (1.96 V 1.87) times your internal gear ratio.
Old 04-25-2014, 10:11 AM
  #102
b20btec's Avatar
Looking back I type in the wrong fdr combo, 93/47. Thanks for noticing.
b20btec is offline
Old 04-25-2014, 02:44 PM
  #103
dizzy1's Avatar
Trader Rating: 29 (100%+)
Sooooo anyone have any updates when they will be available again? Think its been out of stock 7 weeks. These made out of plutonium or rare space metals? Need a 13.5 for Reedy.
dizzy1 is offline
Old 04-25-2014, 04:56 PM
  #104
Josh-n-ya's Avatar
Trader Rating: 95 (100%+)
That's funny, but not. Sorry!
Josh-n-ya is offline
Old 04-26-2014, 11:48 AM
  #105
Still not exactly the same FDR but much closer. Without wanting to start another long drawn out discussion, it's seldom that simply changing the size of the gears while keeping the FDR the SAME results in big changes in lap times. Two biggest benefits of different sized gears (but same FDR) are more efficient gear mesh and slight different CG from moving the motor forward/backward.
