Team Powers Radon esc
Thank you for the information Robert.
http://team-powers.com/index.php?thispage=viewproduct
Brushless Speed Control > Radon Pro(140A) Speed Control (included USB device)
Item no. TP-Radon/Pro-c
Specifications:
- Support 4.0T or over
- Hard Case Dimension:
~39.5mm(Length) x ~30mm(Width) x ~20mm (Height)
- Weight: ~46g (not include wiring and fan)
Features:
- Ultra-smooth, Precise Throttle and Braking Control
- Compatible with Sensored/Sensorless Brushless Motors
- Data Analysis Capability(RPM, Low voltage and ESC temperature)
- HotWire PC Interface for Advanced Programming and Updating
- Easily Programming through the Program card(not included in the package)
- Built-in one touch On/Off switch with LED
- Bulit-in Low voltage cut-off, Overheat protection and signal loss protection
Kind of hard to explain but I tried.
First test last week: Radon 140A - 5.5T Trackstar - 2S - with Pancar 1:10 (motor at 60ºC)
All settings by default for 5.5 and works fine. Now i need more punch in all range i will increase from 6 to 9º (timing boost)? If i change turbo boost from 15 to 12 i will have the same top speed?
Anybody can share his settings?
thanks and regards,
thanks and regards,
thanks and regards,
thanks and regards,
Just picked up a 95a Radon and I like it so far. However there seems to be a very slight initial hesitation on the throttle. I am trying to figure out what is causing that.
