Xray NT1 2014 Specs
#78
#79
Anyone having problems with the spring of the clutch? Its 10mm long and if I adjust it to have 0,7mm preload the spring is fully compressed and all the coils tusch each other. Its like the spring is to long or the tread nut is to short. Advise please. We all use other spring in Denmark
#80
Zero , no shims. And that has not any influencene on the preload. As the nut with the thread is thight all the way to the flywheel. Meaning that something is not right , the clutch pad , or the fly blocks are to thick. Ot the thread is to short
#81
#83
No , have made same question on xray forum , maybe Mario would answer but Nothing so far. Using a unkown silver spring (Think Its cap) and the clutch is working super.
#84
Re: Front Roll Centre
Just noticed that the manual says to have front roll centre set at +0.5mm, but the standard setup sheet says -0.5mm. Which one is it?
Ran my NT1 Pro today and really struggling with turn in, has heaps of mid corner steering. Tried front brace, changed caster but that took away on power steering.
Andrew
Andrew
#85
Andrew
Andrew
#86
Andrew
Andrew
#87
Arms arm forward with spacer in behind. Tried different front roll centre today as well as some increased front bar. But biggest improvement was when I swapped out front and rear diffs to ones with thicker oils. Took some steering away but was a lot more planted and turn in was better.
#88
Front upper arm pin all the way up, and lower arm with spacer in front of arm 2mm back.
Some, most guys even cut the rear of the rear arms 2mm to move them back. I never cut the rear, but wanted to try.
#89
i had this Problem too.
I Think the Reason are old Pictures in the Manual with the wrong mass.
I have shortend the Cone so i come on 9.7mm for the Flywheel Nut.
After that i shimmed the Clutch Gap to 0.6mm an the Endplay to 0.1mm.
Preeload for the Clutch Spring on 0.5mm.
After set ,setup Clutch on Track,
Greetings
MKAH
#90
Try this.
Will Definately feel better
.7 front
Bar ground down to .5
Almost everyone runs 150 000 front oil diff and 60 000 rear
