Looking for help on a broken part.
So today I was enjoying a little off road and this piece snapped (I'm not sure what it is called on an RC car but in real car terms it seems to be apart of the brake rotor if that is any help), I cannot seem to find the proper piece on nitrorcx, do you guys know where I can order this part, Also the car is a tacon rally 1/12.
I have already purchased a new turnbuckle set I just can't seem to find the other.
Here's a few pictures.
wyatt896 . imgur . com /all
Sorry I can't post links yet......
Still don't know what you're asking. Cuz, braking on electric done by the motor. Post photos when you're able. 10 post will be enough.
Super Moderator
That is part of this set.
http://ocdrc-hobbies.com/taspset.html
This is the same site that Terry posted above.
Spindle set Tacon calls it. Other models call it Steering Block. Where it broke check the steering servo, they usually strip gears. Replace with a MG/HT/HS/BB servo.
Rice grains or magots!!! maybe its like a cellphone, got it wet!! lol!!!
Matt how is it in A-Z in the USA!!! Used to live near City Hall off of 9th.
for the rice to work, it should be sealed (like in a baggy), as the rice will absorb moisture from the air, as well as the chassis, reducing effectiveness without sealing from outside air.
so to clear everything up about the pieces name
spindle = steering knuckle = steering block = front bearing carrier( sometimes just bearing carrier)
most common term is probably steering knuckle, or just knuckle.
