Serpent 835 running Lola (parma) body
#46
I didn't run mine, because it was raining the whole day yesterday in my area. I was realy upset. Sure enough I get up this morning and it's nice and sunny, but I have to go to WORK. It seems to be happening more and more...
#47
Originally Posted by Rookie Solara
David..do you mind to share what shore of foams are you running at Racine and Ohio..? 35 F and R...? Thanks, cause I have to start glueing all those foams and start truing them....too many donuts around but don't have enough rims.
I have been using two different types of tyres (lol). I have spend most of my time running donuts from CRC (Track Magnets) and I use 35 shore. I am mounting my own, just as you. I also run some Super G's from Speedline Hobbies. I use these when I want to tighten up the car on slippery tracks. These are also 35's.
#48
Good Lee.............at least, 35 is the number that I should concentrate on, I don't glue tires, I have someone to do that for me, cause we do have quite a lot of donuts laying around and no one is interested to buy them....might as well use them.
Looking forward to meet you at Chicago, Toledo and Hamilton....no way I have the time to go to Detroit..........and good luck at Detroit stage.
#49
I know it's off topic but have any of you 835 runners managed to get alloy pulleys for the side belt.
I am looking for the 24T and 18T pulleys in alloy because they run much truer.
Any info would be appreciated.
#50
Bob,
RB used to sell them for the Serpent cars. Check with your local RB agent to see if they still have them.
Part numbers are as follow.
2002-001
16T Hard Coated Alum. Pulley
2002-002 18T Hard Coated Alum. Pulley
2002-003 24T Hard Coated Alum. Pulley
2002-004 25T Hard Coated Alum. Pulley
2002-005 24T Front Hard Coated Alum. Pulley
2002-006 24T Front Hard Coated Alum. Pulley
2002-007 22T Hardened Alum. Brake Pulley
2002-008 23T Hardened Alum. Brake Pulley
Cheers Al
Cheers Al
#51
Thanks quozl ( Al )
I did a quick search using the numbers below and found all of them listed by a company called New3Racing.
Will give them a try.
Cheers
Cheers
