using 28mm front tires for serpent what is the conversion?
hi' is anybody there using a 28mm front tires for serpent impulse,is there any difference?pls.tell us the conversion is hard to get those 26mm tires here on our area.i heard that i need to change the hex hub like wider than the stock impulse,is this not going to rub on my steering block?and how about my front axle do i need change that too?how i'm going to put my wheel nuts if i'm going to used a wider hex hub?
OHHHH I had that same problem with the wheels and touching the steering block. I found out that the only wheel that fit the serpent is the Touring wheels, not the wheels with extensions on the spoke which grinds on the steering block. Well what i did to fit 26mm regular wheels was get a dremel tool or a hobby knife and cut the spokes to make a curve, so it doesn't come in contact with the steering block. After that it fit perfectly and rotate without touching the block.
Re: using 28mm front tires for serpent what is the conversion?
hex hub
i used the hex hub from kawahara (mugen) and grind the little spacer on the back so its flat out. its a little wider than the serpent one. and used trc tires. their u go!!!!!!!
Re: hex hub
[QUOTE]Originally posted by goldhead
[B]i used the hex hub from kawahara (mugen) and grind the little spacer on the back so its flat out. its a little wider than the serpent one. and used trc tires. their u go!!!!!what 's up goldhead that kawahara hub is that the one on mtx-2 if not where can i get it?Thanks
