Hobby Pro Alloy Clutch Kits and Flywheels!! >
Old 11-20-2013, 11:27 AM
Default Hobby Pro Alloy Clutch Kits and Flywheels!!
CNC Alloy Clutch Shoes hit harder and last longer than standard aluminum clutch shoes. Don't let hung up clutch shoes cost you the podium. Our extremely consistent Alloy Clutch Shoes are produced with high quality CNC Alloy material which stays cooler, expands less under heat, lasts longer and provides a consistent clutch throughout long main events. Each HP Alloy Clutch Set comes with 6 clutch shoes, one set (3pc) 1.0mm clutch springs and one set of 1.1mm clutch springs. (As shown in photo)
Our CNC Hardened Anodized 32mm Flywheel is produced with durability in mind. The polished steel flywheel pins are extremely high pressure fitted and provide extremely smooth clutch action. Our HP flywheel design and shape provides reduced surface area which eliminates clutch shoes from "hanging up". Out perform your competition with our reliable and high quality competition flywheels.
Andrew Smolnik is offline
Old 11-20-2013, 12:12 PM
GMartinez's Avatar
Trader Rating: 91 (100%+)
wrong section andrew
GMartinez is offline
