how to stop backfiring
hi guys whats doin!!!
i got an issue when my hyper .21 is ideling low to medum it will make a popping )backfiring) noise and the stoll.
could it be clutch related at all because i just finished puting my clutch back together or something else to do with my engine ??
that sounds bad
What cause back firing ? What is it ? Is it same as early detonation ?
If back firing = early detonation then you should delay the firing or timing by using one of the following methods: colder plugs, or using lower nitro. Easy right ?
or shimms
BACKFIRING
Check to see that starter box is turning flywheel the correct way.Therefore engine running in right direction.
Have had similar issues only to find +ve and -ve connected back to front.
Originally Posted by dkj-M3
or shimms
