Serpent 960....
#811
Originally Posted by nefastseven
first problem with my 960
it's the pulley solid axle 51T
i don't know what hapened.....
#812
LINK
Here is that link to the new solid pulley.
#813
no link......
#814
#815
ok thank you,but i did'nt find any shop for the price(mushroom and ace hardware have not got this part)
i just dismounted the rear of my 960 and i saw another problem...i hope it's the last time i'll have probleme with this car
look the 2nd gear,in the center where the bearing is placed it misses matter
#816
ha nefastseven did ether one of the bearing go bad on that gear ?
#817
Unless I am mistaken, I think that is just excess flashing from the molding process, that can be trimmed away, and has no effect on the bearing placement. I have run across it on a couple gears and just trimmed it with an hobby knife and it worked just fine.
#818
but if I withdraw the matter supplement the bearing will not hold any more
#819
nefastseven as long as the flange bearing holds in place and the back bearing surface is not damage then you will not have a problem. with those two things good the gear will run true on the shaft.
#820
#821
anyone knows the price for the Pulley Solid axle 51T Fast ? #903198
because i found the price for the normal pulley which is in the kit(approximately 10$) but not the other
Thank you
Thank you
#823
Thank you
Thank you
#824
in France it costs 30€
#825
OOPS..Forgot the link. Thanks for getting that captian.
