Serpent 960....
#1996
Originally Posted by scotty gray
if you want me to captian, i will post it here later on tonight.
again nice win at kissimmee jimmy
#1997
allright here we go.
FRONT
sway bar / flat
roll center / -1mm (the new hangers)
shock position / top
shock oil / 40wt
shock piston / 3 hole
shock spring / grey
caster / 5 mm in the back
wheel base / long
down stops / +1
camber / -1
toe / -1.5
width / 251
REAR
sway bar / middle position 45 degree angle
roll center / lower arm all the way up, upper arm out
shock position / on the bottom in the bulkhead
shock oil / 40wt
shock position / 3 hole
shock spring / red
down stops / +8
camber / -3.5/-3
toe / +3.5
width / 265
bodymount / 1 down from the top
hope this helps.
FRONT
sway bar / flat
shock oil / 40wt
shock spring / grey
wheel base / long
down stops / +1
camber / -1
toe / -1.5
width / 251
REAR
shock oil / 40wt
shock spring / red
down stops / +8
camber / -3.5/-3
toe / +3.5
width / 265
hope this helps.
#1998
thanks scotty it will
#1999
paolo ygpm
#2000
i see you pooh
#2001
Originally Posted by captian
i see you pooh
#2002
paolo ygpm
Pooh: how is your electric car
#2003
Originally Posted by Paolo M
got it!!
#2004
Guys,
I found that different geometries applications work a not in the same way than what the books and the theory says and that the precious experience you may have . For me this happen from 950 series to 960, but also from 1/8 scale to sedan.
So what i have learned is that when i have a new car, is a totally new world. I try every single adjustment to see the effect. Of course the std stuff works the same (droop, camber, caster, toe, etc. etc) but specially the roll center is different in every car. I think that maybe this is one of the reasons why some time people is not happy with a certain product. They are used to work in a way and try to apply what they know works on the new car and they get frustrated cause the result is not what they expect. Well, my suggestion is take your time, try to work with open mind and you will be surprised with the results.
Taner: Lower upper position gives you more steering (initial)
Upper longer arms gives you more steering (overall) New pulley is basically the same fast pulley but now will have a clip to be keep it in place.
Nigel: nice colors on the avatar
Scotty: great race last weekend.
#2005
Originally Posted by Pooh2
I think I'm done with electric. I can't take 8 min mains. I need at least 20 mins 2 get the monkey off my back. 12scale just didn't cut it 4 me. But, it was fun.
i feel you...... damn for real, you are everywhere
#2006
Scotty congrats my brother, are we going to sin city in April?
#2007
thanks alot Paolo,
hey niggles what going on, what race is in April?
#2008
#2009
I'm everywhere...
#2010
thanks alot Paolo,
are you still "bored" at work? haha!
