Serpent 960....
#1936
Originally Posted by Taner
I m not sure with the new bearing kits. The bearings are to small for this much power. This is not good/ enough strong for a 21. powered on road car. I thing the life-s for this dimesion bearings is not long enough.
#1937
Registered User
Is that you Mr Shing?
#1938
I was racing Centax I with a SX21 Evo2 and it never broked greased, but when I changed to DSII the problems started
anyway
I will order a Centax II should I change the flywheel too? I'm using standard parts of Vector 98
another question.. Could I use the same pinions? Have to upgrade the spur gear too?
anyway
#1939
Originally Posted by jeff1
anyway
anyway
well the new flywheel is lighter than the old one. better for spool up
#1941
Thanks guys
i'm going to order these parts
#1942
i am about to get a 960,what are some options i need to get to start out with?whazt type of engine i need to get also?thanks....rob
#1943
Thanks guys
#1944
another newbie question
do i have to change the flywheel for 38mm #6579?
http://www.serpent.com/product/6579/
#1945
#1946
Bushing / bearing set ceramic
Hey Guy's i Just upgraded to the Bushing /ceramic bearing set
on the 960, but four Bushing/ ceramic bearing are left over are those spear's? please let me know....
#1947
#1948
Originally Posted by masa227
Did you forget to put them on the rear axle and front oneway?
#1949
any pics or word on how the serpent team is doing ?????
#1950
GO TEAM SERPENT!
