Team Associated TC6.2 Touring Car
#961
We have a bunch of stuff coming over the next few weeks Kevin, so stay tuned.
Amongst the items we have a long swaybar kit for the rear, new servo mount and steering posts, aluminum chassis and other goodies as well.
The hold down system uses an m3x 6 screw. Anything with a 3mm thread should work.
#962
Nice!
The aluminiumchassis in touring cars is to have a lower cog? So it will be a little more heavy than the stock cfk chassis? Does it change the flex, too? The operational area will be high grip/bite surfaces then?
#963
The chassis weight will be trimmed down as much as possible. To keep it close to the stock weight.
I am not sure it is only a positive in high bite. I sat with the Yokomo guys at the Worlds warmup and 2 of their guys ran one with a lot of success. The tires did not have a lot of grip, so I think there are benefits to it in certain conditions. The main feedback was that it made the car easier to drive.
I think it also aids in making the electronics run cooler as it will dissipate heat better. We also changed the shape of the car to help it roll a bit more naturally without the front digging into the track surface too early, which I feel the 6.2 does too much. We will release a carbon version of it as well. Both chassis will have an option to use a different motor mount as well.
#964
#965
So yesterday, I received my slipper spool I ordered for my car. The instructions said to tighten the slipper down so I did and the nut stripped out before it was anywhere near tight and made the spool unusable for right now. My question is would the the thrust screw and t-nut from a B4 ball diff work in the TC6 slipper spool? Has anyone ever had this issue and tried that? Or do I just get a replacement nut and pray it doesnt strip?
#966
#967
I would not really call it another car, as we just make option parts to improve the experience with the TC6 platform. Our goal has always been to drive and refine the chassis kits we work on to make them more reliable, more durable, easier to use and if possible, faster. For some, this will be the case and for others they like to keep everything "factory". That's why we are an option parts company and not a mandatory parts company
#969
#970
A spool versus gear diff is a tuning option. I usually use a gear diff outdoors and a spool indoors on carpet.
#971
We will sell the chassis separately from the top deck. The aluminum chassis works best with the stock top deck. So far I can tell you that the chassis makes the car very predictable and super stable. The stock carbon chassis on the other hand, makes the car "feel" quicker but lap times on our medium grip carpet are actually marginally faster with the aluminum chassis. The car seems to switch directions better with the aluminum deck. You can really feel the weight down low.
The servo mount will be sold separately, that should be ready for sale over the weekend. I really like the added precision of it. It did not really make the car faster, but it did allow us to run cleaner with less mistakes over 6 minutes. The car always tracks straight and no longer tweaks after tapping boards.
The motor mount we are still playing around with, but it is a similar motor mount to the Yokomo 2014. It provides slightly more rotation, but at the same time gives more forward bite. This might be packaged together down the road with the chassis kit, but I am still not certain.
#974
Here's a pair of pictures of my car with the chassis and servo mount. Excuse the Yokomo shocks, I was just doing a back to back comparison today and when I took the pics, they just happened to be on there. I honestly notice no difference in performance or laptimes between the two.
#975
_______________________
TC6.2 MUCHMORE FLETA PRO MUCHMORE FLETA ZX 4.5
HITEC SPEKTRUM RSD
