Team Associated TC6.2 Touring Car
#256
Your guy's track is much much larger than ours ill attach the latest layout each lane is about 8ft wide
#257
Should I build with standard or yokomo rod ends? Standard pistons and blades or use Reflex Racing? What are most everyone putting on the 6.2?
#258
well assuming that the ae rod ends are the same as the ones on the 6/6.1 so probably yokomo and i think the two blade are just about the same
#260
#261
does anyone have set ups for the 6.2 besides the two on ae site?
#263
ok so your saying i should run the kit set up? and also my car is HOOKED UP at my track on the last 3 lay outs i have only changed my rear droop settings to make the car work. with my car being a 6.1 non worlds car itd be difficult to replicate the set up, i doubt its possible without some more knowledge that i cant find
#265
Does anyone know if there is a UK release date for the TC6.2 yet?
#266
The middle spot on the tower but with no washers under either side of the link for front and rear I also run sweep how would I put that into this car? Would I change the plugs to a size larger in the front?
#268
#270
Yes, That or YOKBD7 5mm hex's.
http://www.amainhobbies.com/product_...heel-Hub-Set-2
http://www.reflexracing.net/RSD-AE-T...cs_p_1671.html
