Team Associated TC6.2 Touring Car
#2462
#2463
*delete*
#2464
Swap
I'm going to try the TC7 update on one of 6.2 and this is whats in the shopping cart right now. If I'm reading the posts correctly, the only thing that i should be removing are the steering block correct? Most are on back order though.
TC7 Kingpin Bushings [ASC31680]
Team Associated 3x0.5x8mm Set Screw (6) [ASC4670]
TC7 Steering Blocks [ASC31679] ??????
TC7 Rear Hubs [ASC31681]
TC7 Hinge Pin Set [ASC31677]
TC7 Rear Suspension Arm Set (2) [ASC31674]
TC7 4° Caster Block Set [ASC31678]
TC7 Front Suspension Arm Set (2) [ASC31673]
#2465
Also, without trying the shock and sway bar changes first try removing all shims under the rear ball stud bulkhead side. This make it roll less but if it still rolls that much you will have to resort to the first changes I advised. Another thing I am going to test that is aimed to fix this over roll is more shims under the rear arm holders, give me a couple weeks to test that thoroughly.
#2466
Whoa that took some time! Well now that I tested the higher rear roll center I am pleased with the car. It was a quick test and will need further validation, now the car drives more smoothly through corners instead of swing the rear and hook again and also no more twitchy steering. Two birds with one stone.
#2467
Raised 1.0mm front-rear and rear-rear holders from 0.5mm (for a total of 1.5mm). Maybe I will raise a bit further while keeping the rear arms level and work on ride height and camber link shims, my intent is to have roll center at ground level during most of the roll motion.
Stock was horrible to say the least, too much steering both entering and exiting turns on asphalt. Today was damp but the car actually had more rear traction than when I raced it the last time (October/November). Felt like it was a bit softer and compliant, instead of a plank.
#2468
#2470
My 6.2 is really planted and so much easier to drive. more importantly it's faster too.
#2471
Are you talking electronics or FDR?
If you are asking about "gearing", it all depends on track layout and size.
In most cases you will use an 86-96 tooth spurs and 47-56 tooth pinions depending on where you run. On a medium sized outdoor track you want to get to ~3.5 to 3.8 FDR but like I said we need more info.
1)motor brand and model
2)track size and layout (including straight length)
#2472
I have found that 0.5mm in the rear blocks and 0.0 in the front provides a good roll center balance on the 6.2 as well as the yellow sway bar in the front to balance the added front chassis roll.
#2474
Ok, that fits to my experience.
On carpet I tend to use 0.5 under front and rear blocks and put the front rollcenter even a little higher by lowering the inner camberlink mount by 1mm.
Otherwise the rear started kicking ...
But on asphalt I'd also go the other way.
#2475
Here's the setup on non conventional setup sheet.
