Indoor carpet - Track building materials
Hi guys, Sorry to repeat a thread that I know will of been run in the past, but I'm hoping I could get some advice on the materials used to build corners for indoor carpet track layouts.
We currently have used white plastic bent around on the edges of black drain tubing. The stuff we have is a really brittle and shatters too easily.
Is there a certain type of plastic to use that is much stronger than others, and what dimensions do you use?
Do people pack the corners with foam?
Any other types of corners made out of other material?
thanks a lot!
Andy
thanks a lot!
Andy
We are currently using old plow disks to form corners and it has helped alot. Track changes are quicker and crashes are less costly (fewer broken parts, easier on the bodies).
Previously we had 90* wooden arches that worked pretty well but were harder to move around and more destructive on bodies.
if you look on the thread from the Halloween race from the Gate, their track boards and corners are terriffic. Very easy on the cars, they don't move, and the provide excellent visual definition for the track layout. I'm not the only one who attended that race who was commenting on how nice the Gate's layout boards and their soft corners were. Much better than dots and better even than the somewhat costly plastic clicktrack barriers.
Wood Shims:
http://www.homedepot.com/p/Unbranded...0#.UnrVp-IwIS4
I'll have to get a few pictures tomorrow night of the board ends to make it clearer.
Many years ago we used discarded escalator handrail. At the time, it was free for the taking whenever the local escalator service company replaced worn handrail (which was quite often). I don't know if they recycle the stuff now, or still just throw it in the trash.
The handrail was heavy, so it didn't move too much, but still had enough give to absorb some impacts. One nice thing about it was that it was easy to form sweeping corners, as opposed to straight lines and sharp corners like with 2x4's. But it did need to be faced with some type of thin plastic, since tires had good traction on it (when a car brushed the wall, it wouldn't slide off, it would just stop dead).
Pictures of track boards
A shot of the track with multiple flappers
Don't forget the 3-in-1 oil and gauze pads.
We use old fire hose filled with sand. It makes good flowing track as you can bend it curve to any line you like. But you need to seal the end's so the sand do,s not come out.
CRC's Clik Trak works really well. It's light, easy on cars and clicks together fast for making quick but professional layouts. Used at the Snowbirds, IFMAR World Championships and other large events, Clik Trak is again back in production. We had a tooling issue, but now fixed with our first production due in stock in a few weeks.
Check it out here.
New 2014 pricing and kit sizes will be posted soon.
Check it out here.
thanks a lot!
Andy
thanks a lot!
Andy
