Xray X1 - Formula One Car
#1518
I had that body on my CRC F1 and it took a lot of cutting to get the pod to work freely. Cut a little at a time and keep checking it. You will remove most of the back end, but it absolutely needs to be clearanced around the pod and motor wires.
#1519
Cut, fit, cut, fit, cut, fit, ect....
#1520
Yeah I got me an X1 built up. Now comes to see if I can find time to race. Hopefully soon. Painting now.
Hi Joey-san... nice looking ride! <waves>
#1521
#1522
I also had to cut the entire rear of the Xray body to make it fit my 3racing fgx....I ended up with a 27gram f1 nose&helmet body.....Good luck ...
#1524
Set the body on the mounts.
Shine a bright light under the car so you can see the posts through the paint.
Cut the rear holes first.
With the body all the way down on the rear posts, use the light to find the front post.
Protoform bodies need a ton of hacking to fit on the Xray. I hacked all the way forward to the rear sidelink balls.
#1526
That's the awesome thing when you run an xray body on the xray, the holes are marked perfectly already on the body!
Plus the xray body has cheater LCG since the helmet is molded
