Mugen MTX-3
Old 04-19-2005, 06:21 PM
  #14956
roadrage's Avatar
Trader Rating: 14 (100%+)
Default Re: rear end traction
Originally posted by gentleman81
what is the trick to getting the rear end of the mtx3 to stay planted in the turns, tight turns at that. i intially had a problem with turn in and pushing alot, now i have that pretty much under control. now the car wants to whip around no brakes applied? i can turn in fine but mid corner it will just spin out most of the times off throttle. where would i go from stock setup.
i have the 2.5mm sway at the softest setting (at the ends)
and the front bar flat (softest also)
dark blue springs at the lowest wholes
try putting the light blue springs on, since they are softer this will give it more rear end grip, but also cause it to push coming out of the turn.
roadrage is offline
Old 04-19-2005, 09:33 PM
  #14957
MAVICXXX's Avatar
Default shifter jammed
sorry guys to interrupt can somebody guide me how to cater the shifter jammed problem?I knew u guys discuss before and i m running out of time coz d asian final round is getting close and i v got to make use to d car s i v never drive mugen before,this is my fisrt time driving as being sponsor by d organizer in Malaysia.
Do appreciate if you guys can help me out,d best that u hv come across to counter it.pliss..
MAVICXXX is offline
Old 04-19-2005, 10:41 PM
  #14958
Tech Prophet
InitialD's Avatar
When the rear end wants to swap ends, try a harder front sway bar setup (more vertical instead of flat soft setting).
Perhaps you want to give a mote detailed setup like droop, camber, toe in / out etc and the guys would probably be able to trouble shoot your problem better.
InitialD is offline
Old 04-19-2005, 10:46 PM
  #14959
Tech Prophet
InitialD's Avatar
Default Re: shifter jammed
So fast already jammed?
What is jammed? You meant the 2 speed oneway bearing?
InitialD is offline
Old 04-19-2005, 10:49 PM
  #14960
MAVICXXX's Avatar
Default Re: Re: shifter jammed
2nd gear shift clucth unit.
MAVICXXX is offline
Old 04-19-2005, 11:07 PM
  #14961
Trader Rating: 28 (100%+)
The only time I have seen the 2 speed lock is when the the 2-speed shoes rotate on the center piece. You need to get the 2 speed assembled correctly and I tighten the center screws and those little balls down as tight as they will get without separating the two speed shoes. If they arent snug then the shoes will rotate on the center and jam the 2 speed.
Scott Fisher is offline
Old 04-20-2005, 02:32 AM
  #14962
asw7576's Avatar
I don't use the ball anymore for 2 speed. Instead I use longer screws (8mm) and directly tighten all the way down. The shift is awesome.... great punch. The ball setup allows you shifting much softer but sometimes the balls get jammed and ruined the clutch.
asw7576 is offline
Old 04-20-2005, 01:27 PM
  #14963
gentleman81's Avatar
Default my set up
front sway bar flat
35 shore fronts
dark blue springs
stock shock oil
shocks in lowest whole on tower
4-5 mm ride height
1.5 deg camber
caster 2mm
toe out .5 - 1.5mm
rebound ???
bump stop???
B ackerman
rear ride height 5-6
camber 3.5
toe 2.5
C rear block
2.5 rear sway at the softest setting
no shims on rear uprights (just removed, tip from another driver)
gentleman81 is offline
Old 04-20-2005, 01:29 PM
  #14964
from this setup what can be done to better traction especially the rear end?
Old 04-20-2005, 01:34 PM
  #14965
Derby Bros Racing's Avatar
you didn't mention the shore for rear tires...
use the same shore as the front for rear or use harder front tires.
try the same ride height front and rear. 5mm is a good start.
Derby Bros Racing is offline
Old 04-20-2005, 01:48 PM
  #14966
thanks man, by the way i like that paint job.
Old 04-20-2005, 01:51 PM
  #14967
let me know how it goes. remember, try to do one change at a time so you get to feel the difference each adjustment makes. this helps a lot to get to know the car.
Old 04-20-2005, 06:50 PM
  #14968
dg8one's Avatar
hey gentleman81 what part of VA you race?
dg8one is offline
Old 04-20-2005, 07:10 PM
  #14969
Trader Rating: 17 (100%+)
Gentlemen81,
Try going to the B block in the rear as this will instantly change your roll-center and give you more rear traction. If thats not enough go to the A block. You could also try a longer rear camber link for more roll. The list could go on and on, but try this as it has an immediate effect on handling characteristics.
Jamie Corrado is offline
Old 04-20-2005, 08:44 PM
  #14970
so am i wrong about the rear block, i though the C was the block for low traction tracks and A was the block for the high traction tracks?
thanks for the entire boards input on my ???'s
