Mugen MTX-3
Old 07-21-2004, 05:07 AM
  #13381
alucard13's Avatar
I am in the procss of building my Prospec and have assembled the rear end and 2 speed. I do not have wheels on it yet to to test to make sure the belts were moving smoothly i would either spin the back diff or take the middle belt and move that back and forth. when i do this however i hear a clicking noise that seems to be coming from the 2speed. When i assembled it i did not notice anything sticking out or onstruction the gears or bearings. If i move the middle belt slowly it will stop unless i give it more force.
alucard13 is offline
Old 07-21-2004, 06:15 AM
  #13382
gonzoY5's Avatar
Yeah I had a noise similar to that at first too. It turned out to be the two speed shoes lighty rubbing one of the three screws on the inside of the 2nd gear housing. Check that they're in all the way.
gonzoY5 is offline
Old 07-21-2004, 08:42 AM
  #13383
alucard13's Avatar
Will do. I may be able to finish this thing in the next few days. Can't wait.
Old 07-21-2004, 08:54 AM
  #13384
gonzoY5's Avatar
Yeah man, try to get it ready for Saturday, we'll all be out there. I can help you if you need.
gonzoY5 is offline
Old 07-21-2004, 11:25 AM
  #13385
Mugen X-12
Does anyone know the price of this engine? Has anyone used it yet? Any comments? I'm thinking of getting one for $260. For the same price, should I get Nova Rossi S3, instead?
RC Dumb is offline
Old 07-21-2004, 11:58 AM
  #13386
Default Re: Mugen X-12
Look on ebay there is a JP mod X12. That is the one you should be looking to buy.
vadn1 is offline
Old 07-21-2004, 12:06 PM
  #13387
Default Re: Re: Mugen X-12
JP and X12? not JP FX? thought somebody else mod the X12, not JP, please verify.
RC Dumb is offline
Old 07-21-2004, 01:42 PM
  #13388
roadrage's Avatar
Trader Rating: 14 (100%+)
maxy mod. does x12's for $350, or you can give him a brand new x12 + $80 and he will give u 1 already mod.
roadrage is offline
Old 07-21-2004, 06:30 PM
  #13389
GrandeGixxer's Avatar
Trader Rating: 21 (100%+)
are they still having the problem of not being able to make 5 minutes with the X12?
GrandeGixxer is offline
Old 07-21-2004, 09:58 PM
  #13390
rcabj's Avatar
Default ride height???
Originally posted by kt racing
A block is for smooth tracks gives you less traction.
B block is for semi smooth tracks gives you a little more traction.
C block is for ruff tracks gives you the most traction.
I usually start with the B block and go from there.
keith
correct me if i'm wrong.....so this rear block selection has nothing to do with ride height....
height adjustment is by adjusting the shock spring or different shock tower position..right
rcabj is offline
Old 07-21-2004, 10:00 PM
  #13391
Default Re: ride height???
Yeap!
Johnnytc3 is offline
Old 07-22-2004, 12:21 AM
  #13392
theRED5's Avatar
I have just started running a JP FX 12 T-O3 S(tock) and although I only have one days experience with it, It made 5 minutes better than my NSR 12 S3. I had fuel still in the tank after all 3 heats last Sunday.
theRED5 is offline
Old 07-22-2004, 12:43 AM
  #13393
different carbs, different engines, different fuel comsumptions. Results are inconclusive, since it depends on weather, temp on engine, condition of track, and how you adjust each engine accordingly.
RC Dumb is offline
Old 07-22-2004, 07:48 AM
  #13394
Taylor-Racing's Avatar
Guys,
I need to build a front diff for use at a tight track and figure I need the following parts:
T0220 Diff Pulley
C0228 Diff Gear W/O-Ring
T0202 Diff. Cup Joint
T0207 Diff. Gasket
T0215 Joint Pin (2 x 9.8)
C0227 Spacer
I have the diff case that came with the kit. Have I forgotton anything?
Thanks in advance.
Taylor-Racing is offline
Old 07-22-2004, 08:13 AM
  #13395
cdelong's Avatar
Trader Rating: 12 (100%+)
I think you're missing cross shafts or the retaining pins?? Not sure by the descriptions/PN's.
cdelong is offline
