Mugen MTX-3
ETF
Did you see this?
Originally posted by eddiethefish
POS=Prince of Straight-away...
That reminds me to change the Front Belt from MRX-3 back to MTX-3 one.
Don't know about others, but the MRX-3 one fits on the pulleys so well that it binds the whole front tranny.
30%? You guys run 30%?
BTW...
I GOT A PROSPEC !!! YAY
me two
Will do. But, didn't the manual once indicated we should ca it to the pulley?
I'll see if mine come off easily, or else I'll just use the reg. front belt.
thanks,
thanks,
Originally posted by Ah10
You need to flip the side washer on the pulley backward so it wont bind
Re: ETF
wife commented that she wished that fish tongue were real on me.
Originally posted by Slotmachine
Did you see this?
Did you see this?
guys ultimate has the prospec for $469.95
er
Originally posted by Profoxcg
please dont have me
please dont have me
spell check required
sorry, ok i fixed it its late
Originally posted by Data
Mugen MTX-3 POS POS POS
It's the same at Elite Hobby Shop.
Originally posted by gentleman81
what type shaft on the motor does the mtx 3 need?
Very few things have let me down over the past 18 months running the MTX but the following can fail.
The front dog bones bind a little at full steering and will pop out if you hit something mid corner.
Eventually the plastic wheel hexes will rub on the bearing especially if you lose a wheel and start putting extra effort into doing the nuts up tight.
Wire belt tensioners are just pox.
The two speed shoes will fail at some point, the grub screw that sets the gap can strip. This happens after the cam has a nice little groove worn into it. It's not a big deal you just need to keep an eye on it.
When you get this thing on the track go as slow as you need to make sure you stay on the track. If you need to be marshalled often you will not win.
Good luck.
