Mugen MTX-3
#7471
CASE IN POINT
The Guy simply asked why is this shoe better than any other. 4 BS answers and 1 worth a damn
#7472
Re: CASE IN POINT
isnt it a rule of thumb? harder last longer, doesnt grip as much as softer one? I guess it would apply to foam tires too! Also there is no such thing as "Better", all depends on tract condition, driver and set up!
and besides I know the person who asked this question very well, so I know if I listed the differences he will make the right judgement if it is better for him or not!
#7473
Thanks ah10!
#7474
Re: Re: CASE IN POINT
Originally posted by Ah10
Well may be you just didnt get what I posted! you are just not as smart as I thought you are! Or may be your statement is just a BS statement!
i remeber this guy was complaining too many BS on this thread but i think his last one is a true BS and was trying to push off someone from asking question here. there was no obvious answer to his question until the one i quoted from you above.
"it is good" is not an answer. "I love it" is not an answer. they are just end result but they never said anything about "How" and "what" to make the red better.
#7475
wow even longer lasting that the stock one?
i never thought that the clutch will wear out, mine still looks like new after 2 gallons, maybe my engine is too weak
#7477
Different hardness clutch shoe will allow you with different centex adjustments, for example if you are setting your centex to engage late for the punch then you probably need a softer material clutch shoe to grab fast and hard when contact(instead of slipping) since the clutch bell is spinning relatively fast! on the same token, if you set your centex engage early then you probably could use harder material clutch shoe.
#7478
Manti, correct me if I am wrong.
yes you are right, if you set a soft pad engage too early or a harder pad engage late, you will lost power.
#7479
Originally posted by Manticore
IMO the harder the pad will give you more linear power curve while softer pad will give you more punchy feel. i.e. they are also related to condition of the track.
Vaurth read this I believe you had asked me this question a while ago!
#7480
one very important note.
delta red may not = mugen red pad. await for verification from Robbi ??
#7481
red pad, great!!
Something new to try
#7482
Originally posted by snoopy
red pad, great!!
red pad, great!!
#7483
right !! too boring while the car has too little problem to talk about !
#7484
Red pads are the same material...
That is all I use, in both the mtx and mrx it will glaze up, I like this, then it stays the same for a while i have had mine in since jan and I kinda run alot...maybe average 3 to 4 times a week.
I also use the silver spring and drill out the lightened fly weight to 4mm.
Ron
Ron
#7485
Wow! You guys are too serious.
The guys simply were joking with their friends and some one don't like it already.
The guy simply pointed out this thread is mostly BS and some one don't like it already.
No matter what, I think this thread is OK becasue at least you guys are not kissing each other's a$$.
