Mugen MTX-3
#7276
Re: Re: MTX3 2.0
Originally posted by Corse-R
Huh! almost finishing the assembly but is loaded with hop-ups (maniac ) only one thing disappoints me. Those K-factory wheel hex (got a set for mine MTX3 and one was eccentric - put some Kawa instead).
Playing with the 'dark side'? When you will sell your Mugen and got the 705?
#7277
all three are good cars
#7278
For Crystal Park, what variations to the stock setup did you make on your car? I remember you telling a ride height of 5mm front/6mm rear(isn't that kinda high?), I forgot the others.
How about for Rev?
Also what 0.8 module gearing is good for a big track like CP? I'm currently using 17/22(MRX3 pinion) 47/42.
Thanks dude
#7279
Originally posted by BOLISARIO
Hey Robbie, a few questions:
How about for Rev?
Thanks dude
How about for Rev?
Thanks dude
I think this gearing should work fine at CP (21/59 26/52) if you need moore top end you can use 27 on second gear.
#7280
what oil??
Use the same fuel for break-in and racing. I routinely use a 11% of oil on mine engines and go up to an 8% under racing. So for me a 18% of is too extreme (probably in off-road cars is needed, here you don't need as much oil), you will be quite happy around 12%.
Manticore or others with electric connections: I'm searching for a pack of Shock diaphragms from RaySpeed (Japanese guy) for the Yokomo MR4-SD. I'm searching the hardest and the softest ones, anyone know where are available? wanted to try.
#7281
hey guys, just got the new 0.8 gears for the 3. I got 21/60 and 29/52. Gave up little accel, but top end is CRAZY!!!
Nitro Rules
Nitro Rules
#7282
Re: what oil?? (Fuels and some tricks).
Originally posted by JustRace
Corse...8% oil?? Are you mixing your own fuel? What oil are you using and do you add castor to the mix?
For one litre at 8% oil (16% nitro):
- 60cc of Castor (Klotz Benol).
- 20cc of Synthetic (Klotz Original techniplate).
- 160cc of Nitromethane.
- 760cc of Methanol.
For one litre at 11% oil (16% nitro):
- 80cc of Castor
- 30cc of Synthetic
- 730cc of Methanol.
If you see I use much more Castor than is normally used on commercial fuels. Castor is the unique who saves your engine from a ugly breakage when whining at more than 35Krpms. The 'unique' tradeoff of this is a little more residues on your exhaust and the piston (easily cleaned).
Just some warning about this. Those mixes aren't suitable for winter (or when temps goes down 15ºC). Castor at low temperatures doesn't work very well and needs some help from Synthetic oil.
To make them more 'cold friendly', just substract a 2% of Castor and add an additional 2% of Synth to the 8% mix and the same for the 11% mix. Works really really well, honest.
Those oil percentages are for mix from 16 to 25%. If you want to go at 30%, probably need a little more oil (add 1% of more synthetic oil to those figures). Those mix gives you much more Nitro and Methanol into your chamber than commercial fuels, so more bang in your engine, take care.
Another 'Warning'... if you go at 8% oil, you're slightly under what Novarrosi advises for their engines (they want a 10% oil, and this fuel requires to have a serious grasp doing carb adjustments) and probably P/S life is sligtly reduced, but the last time I did more than 15 litres over the piston with those fuel and then P/S went for practice and playing.
We're completely off-topic here. If you want to talk about fuels, let's make another thread.
#7283
#7284
Re: Re: MTX3 2.0
#7285
Re: Re: what oil?? (Fuels and some tricks).
#7286
Re: MTX-3 Floating version 01
Originally posted by esham
Done with my conversion. But not really test it yet for full track coverage. But for those just want to be different Have a look on the attachment .
#7287
Re: MTX3 2.0
Originally posted by Manticore
#7288
Re: Re: MTX3 2.0
Originally posted by RClover
Feeling hungry huh? Nissin Instant Noodle..
#7289
what power plant you gonna put in there?
#7290
