Mugen MTX-3
#3811
Originally posted by RClover
u mean more neg. camber?
i take that you are on Front One-Way/ Solid Rear combo?
cheers
cheers
#3812
me too
#3813
mtx 3 questions
hi guys i have a couple questions?
1-do the hinge pins from the mtx2 fit the mtx3(wnat to order some titanium ones from kawahara)
2-i saw a pic of five stars shock shaft on rc world are they titanium nitrited coated any info on these shafts
3-i saw a picture of kawahara belts for the mtx3 are these replacement belts (stronger may be) or some kind of overdrive belt combo.
any help will be greatelly appreciatted
thanjks
thanjks
#3814
Re: mtx 3 questions
thanjks
thanjks
2/. i am using them ! smooth
3/. not stronger, but shorter 363mm. you need to use 19T in front and 16T in rear. i am using them too.
#3815
MTX Belts
Chewed up a rear belt and my LHS didn't have a replacement. It seems the Trinity Reflex NT rear belt is the exact same size. Perfect fit! Does anybody else know if other cars use the same front and side belt as the mtx3?
I also run at tracks that run rubber tires. The Takeoff preglued fit very well w/o rubbing. What other wheels will work?
#3816
Re: MTX Belts
Rclover told us the V1RR special side belt (375mm) does fit the MTX3.
#3817
Re: Re: mtx 3 questions
Originally posted by Manticore
1/. yes
1/. yes
3. learnt that the kawaha shorter belt with the 19/T and 16T will obtain a better tyre consumption. the front and real wil consume the same rate...is that right ?
#3818
Re: Re: Re: mtx 3 questions
the 19/16 provides you OD in the front i.e. you may use smaller front tire to improve steering characteristic. diameter split front and rear is 3mm to obtain 1:1 ratio.
#3819
u mean to swap the stock front 16T with the rear 19T brake pulley?
#3820
hey guys i been runnin my mtx3 for a couple of weeks now and still lack of rear traction pls help
set up according to the set up sheet except for the front diff
30000 front 7000 rear
nelly
nelly
#3821
why run a dif but if you must 100000 in front and 3000 in rear if that doesn't give you rear traction nothing will.
#3822
It is not always a diff issue when your rear end is loose.
the setup sheet said rear camber is 3' but I end up using 4' and 2.5' rear toe.
this gives me good rear traction.
You also need to check rear ride high to make sure your rear end doesnt scratches the ground on cornering.
#3823
nelly
nelly
#3824
All MTX-3 owners will enjoy this: latest press release on the NTC3 "The Fix" issue
#3825
