Mugen MTX-3
Old 04-28-2003, 02:26 AM
  #3361
Vinyard's Avatar
nah not parking lots.
its a new local track. it made on 2 tennis courts.
the surface is rubberised.
the track has got very good traction.. after last sunday's local race.. it gotten oily.
my mtx-3 is still stock and been bashed and abuse alot. havent change much execpt for the purple springs. and the adjustable rear sway bar.
Vinyard is offline
Old 04-28-2003, 02:41 AM
  #3362
chookgb's Avatar
Trader Rating: 29 (100%+)
Default Re: sliding.
Originally posted by Vinyard
my mtx-3 spins off too much when i throttle after the turn.
couldn't get the car to grip on turns.. sigh.
what else can i do? i already toe-in 3degree and using 37 shore.
other cars are doing fine execpt mine.
what steering ackerman are you running i would suggest the b one and also what tyres are you running on the front and what springs
chookgb is offline
Old 04-28-2003, 03:39 AM
  #3363
Vinyard's Avatar
B ackerman 37 all round.
Vinyard is offline
Old 04-28-2003, 03:43 AM
  #3364
Default Re: Re: Foams
Originally posted by BOLISARIO
Anyone?
Also, do the 730 Rx packs have good enough run time or will it fall short in long mains?
Bolisario--
I run either the FAST or Super G tires. The Super G 0 offset (which I think is actaully 1mm offset) fits the front fine, but won't fit the rear. You have to use the 2mm offset on the rear.
The 730 packs seem to be fine if you're using standard servos, but it just doesn't hold up using digital servos. I run at some tracks that run 20-30 min mains. I run digital servos, and my pack dies about 2-3 min into the mains. I'm barely getting through the qualifiers.
tekrsq is offline
Old 04-28-2003, 04:37 AM
  #3365
chookgb's Avatar
you need to try harder tires on the front say 40 or 42
chookgb is offline
Old 04-28-2003, 05:09 AM
  #3366
Corse-R's Avatar
Default Re: Re: Re: Foams
Got some runtime problems with 2 digital servos and one pack. Made by myself another pack with 750Mah AAA Sanyo cells and runtime got much better.
The problem is having two digital servos on your car, they draw a lot of current. Change your throttle servo for a 'Non Digital' one and your problems are gone. In fact I'm capable of running 50 minutes with the Sanyo cells pack and one Futaba 9450 on steering and one 9402 at throttle/brake.
Corse-R is offline
Old 04-28-2003, 05:23 AM
  #3367
snoopy's Avatar
If your having problems with your RX pack, then get hold of 5/4 AAA cells and make up a 850mah pack.
Everyone at our club uses this pack on their MTX3
snoopy is offline
Old 04-28-2003, 05:26 AM
  #3368
sparksy's Avatar
Trader Rating: 14 (94%+)
I just peak mine on during the lunch brake.....
Have to .... I am running HRS so need both to be digital
sparksy is offline
Old 04-28-2003, 05:32 AM
  #3369
Have you ever used the Sanyo twin cell?
In a shop near by there are some of them and they are 1000mah.
If someone has can you tell me if they need a special charger.
Speed De is offline
Old 04-28-2003, 05:54 AM
  #3370
i have been able to get over an hour of time from my 730mah pack using 2 digital servos on more than one ocassion
during a race day i charge before qualifiers and again before mains but twice when practicing i have gotten over an hour from the pack using the timer on the radio to calculate
i use a hangar 9 double vision is a DC charger that can charge you radio reciever pack and glow plug ignitor all at the same time
jason102276 is offline
Old 04-28-2003, 05:59 AM
  #3371
What is HRS? Thanks
Pepe is offline
Old 04-28-2003, 06:30 AM
  #3372
Manticore's Avatar
Originally posted by Pepe
What is HRS? Thanks
High response system, 3PK, Futaba
Manticore is offline
Old 04-28-2003, 06:32 AM
  #3373
Manticore's Avatar
just got goodies for MTX3 from kawahara
16T with shorter mid belt.
Old 04-28-2003, 06:39 AM
  #3374
Corse-R's Avatar
Aaargh!. An overdrive pulley but not floating body mount???? this isn't fair. Planned seriously to make me one from the photo that posted manti some time ago.
On 15 days we have one race from a new class called 'Lola unlimited'....
The rules? easy:
- Lola VDS body is enforced (there's no place for pimp touring car bodies).
- Slam whatever .12 you want until is a .12cid engine.
- 30% nitro maximum.
- No other limits on pipes or anything, just pure and freakin fast engines, and of course.... Lots of nitro.
Corse-R is offline
Old 04-28-2003, 08:07 AM
  #3375
Manticore's Avatar
The rules? easy:
pretty interesting. we have the same rule here after all but they do restrict body shell to either sedan or Lola.
