Mugen MTX-3
#2926
Re: Question
Originally posted by TonyWest
I have a Question the new MTX 3 seems to be popular. Are they winning at the big races. I heard they just did well at some big race. I here that it is a good car but I was wondering if the car has won any major races yet.
At the 2nd national meeting, was second and the first one needed to retire due a broken bulkhead.
#2927
REAR DIFF
i just got my mtx3 is it better to used a heavier diff oil in the rear diff nor the the oil that came in the kit will b fine with a oneway?
if u used diff front and rear what oil do u guys used?
#2928
Originally posted by penggoy
help pls
im still building this car and i noticed on STEP 7 that u can have ur car with front one way or front differential ? what are u guys using?
Also the front/rear driveshafts come out once I turn the front wheels/ rear wheels. Someone said here to put o-rings. But where?
what bag can I find the rubber tip on the antenna tube?
Are there any other manufacturer selling metal anti roll bar holder because the stocks are made of plastic?
thnx
help pls
thnx
#2929
Originally posted by dg8one
REAR DIFF
REAR DIFF
i run rubber with 100,000 in front and 10.000 in rear
#2930
cartman
thank a lot
any more imfo about the car will b good
thank a lot
#2931
REAR DIFF
REAR DIFF
If you plan to run with foams, my own experiences with the car told me that for doing a good setup of your car you don't need to go much further than the stock setup, probably some slight changes at springs, caster adjustment and probably some of front and rear toe.
Stock setup works real pretty well at every tracks I used my car.
#2932
i heard something about the dogbones in the front of the mtx 3 falling out ? ? is there any way to get around this without buying the universals ?
#2934
is this car ok for a nitro newbie?
#2935
whats the most common size hex in this kit ? ill have to buy some hex wrenches
#2936
hi guys I have a problem again. Its on step 19. Its for the rear suspension arm. How come there are 3 choices for the Arm Pin? What are u using? T0128A-T0129A, T0128B-T0129B or T0128C-T0129C?
#2937
#2938
2mm. I'd have to say that 95% of the screws are 2mm. A great thing to have would be the 2mm adapter for power drills. Saves a lot of time. Does anyone know where I can get one because I am in desperate need of one considering how often I tear apart my cars?
#2939
I saw somewhere either on this forum or somewhere else that sombody used a Trinity Reflex Sealed Receiver box instead of the open Mugen Receiver mount.
Anyone know if this is a direct fit and/or who posted this pic so I can refer to it and ask.
Thanks,
Puma
Thanks,
Puma
#2940
I think Cartman had a Trinity rx box on his MTX-3.
