Mugen MTX-3
Originally Posted by ROBBIE C
Try running the least amount of toe in the rear this should help some with rear tire wear.
I think the yokomo belt works.
Does this 23T Serpent pulley come from the 710, 835, or 950?
Originally Posted by performula
How does someone avoid toe with these cars?
Which Yokomo belt and from which car?
I don't understand your question?
Where else in someone's set-up can "toe in" be avoided (springs, shock oil, etc.)? What's the maximum amount of toe a person should have before they need to focus on a different area for set-up?
0 to 1.5 should more than enough the only time you want to run 2 to 3 degrees of toe is on a extremely high bite track, more toe in will cause the car to push more a keep your car from traction rolling.
When looking for more traction in the rear focus more on the camber and shock position, try giving the car more camber and laying the rear shocks down, you also can play with the camber gain, high the camber gain the more side bite.
This is what I do to prepare my car, just my opions, I'm always open to learn more so if something seem's out of place here please feal free to correct me.
Yes if you add more spacers this will give you more side bite.
Originally Posted by evlhdlts
what's the most spacers you used (2mm??, 3mm??)??
The body also plays a big part in traction, try the Mazda 6, or the Losi Alfa, or the Kawahara Honda all these bodies work great.
The further you move the wing back the more rear traction.
i love the mazda6 body.
anyways, i got a brand new stratus 3.1 that i'm going to try. i wonder how good this one is going to be... it sure looks close to the 6
Where can the Kawahara Honda body be purchased? Kawahara is a little scarce in these areas.
If you ask Ravi over at Fast N Furious he could order it for you.
