after run oil fouling plugs
Until recently I have always used wd-40 as after run oil.. and it was always done after every run. I had never had a plug completely die on me..
The last couple times I used hobbico after run oil and now have a dead plug.. dead meaning there is no glow to it at all..
coincidence or is wd-40 more plug friendly than after run oil?
I've used both and I personally like WD-40. I can't say that the hobbico after-run fouls plugs, but it is a little harder to burn off when it comes time to start the engine again.
either way, I'm going back to using wd40 instead of after run oil..
like they say, if it aint broke dont fix it......
I use Hobbico oil in my motor and use it very liberally and never had it foul a plug, in fact the plug I used to run my motor in is still going strong.
mine was an A5..
An LRP No.7 turbo plug it is their med heat range plug.
the A5 is a colder plug and is probably more likely to be fouled..
but maybe it was just coincidence..
Suggestion: Have an old plug that you use as your “after run oil plug” Use it when starting for the first time after using after run oil. Switch to a “good” plug after the oil is burned out of the cylinder. That way, you don’t have to worry about fouling a “good” plug. After a new plug has several runs on it (before its worn to an unsafe limit! ), it becomes your “after run plug” and so on.
I always use the Hobbyco one or the Team Orion one and never had a single problem other than a lot of smoke when i start my car after a week of resting ... but after a couple of "grrrr !!!" of the engines, all its normal ...
The ones i use are :
and
I just grab the one its closer on my workshop ...
and
A lot of smoke and damn does it smell bad............
bad batch novarossi turbo plugs
reading this thread reminds me of the discussion from last year about some bad batch novarossi plugs. anyone still remember ? was it the 7tf or 7tc ?
