Definitive answer
Neither. Bake the tires off. That way, you don't have a tire foam full of scalding hot water to deal with. 350f for 10 minutes and a pair of oven mits and you're done. Everything is reusable.
Just beware that the acetone eats plastic rims.The oven method works best from what i've been told.
Sean
Sean
acetone is far far easier and it doesnt even touch most tyres, some go funny but do a test on a set you dont care about to make sure.
some tamiya wheels will melt... all prolines, associated, losi etc are fine.
If you steam them, it doesn't affect the rims, Ive don it before you just gotta leave it until the tire starts to peel off.
I use the acetone method. But it's the fumes, not the acetone that breaks the glue bond. I put about a half inch of acetone in a coffee container. Then set the tire on blocks so it is not touching the liquid and put the top on. Let it sit overnight and they'll come off nicely in the morning. Kills the foams though.
