Xray T4'14
#2296
Has anybody news from the titc or a web site to see how its going
#2298
Is this an official xray conversion kit?
http://www.rcsupermarket.com/PDT/Xra...2015_5327.html
#2299
Does anybody have a used T4 2014 chassis they would be willing to sale cheap.
#2300
#2301
Ok guys I got an issue with my rear belt rubbing on the motor mount. Its the white belts front and rear. I just replaced the rear belt last week due to the left side of the belt just being completely worn. The new belt is showing signs of the same wear pattern and I can physically see the belt is just slightly above the motor mount. The tension dowel is up top right in the middle as of now. I have cleaned the belt for next weekend to see if it continues to wear. What should I do? Make the rear and front belts tighter? Replace both belts completely? Just run the rear belt even tighter? Thanks in advance guys. "D"
#2302
Skiddins
#2304
I apologize if this has already been answered but....do aluminum djc exist for this car(like on the Durango)? If so, where where where?
#2305
Found them
#2306
Have to share two more pics of my T4. I run most often on unprepared surfaces so I reduced droop by a couple millimeters for some extra ground clearance; I might try unscrewing the lower shock eyelets a couple turns to lengthen the shocks a bit as well, but that might upset the handling; she's running so beautifully now! So light, taught, and smooth. XRay really did a beautiful job with this car.
Although I have Sorex slicks on in the first, I've been using low-profile HPI Super Radials on the gold wheels. Does anyone have suggestions on good street tires which would work well with light dust or debris found on unprepared / non-race environments?
DSC_4022m2 by Lunitic, on Flickr
Axial SCX-10 and X-Ray T4 2015 by Lunitic, on Flickr
#2307
Is there such as thing as a toe in chart for the T4? One that shows what using the different 0.5 or 1.0 inserts does?
#2309
Can a 2014 T4 be converted to a '16?
#2310
