Xray T4'14
#1786
#1787
This can be replicated by simply adding more weight preferably to the front of the car and raising your roll center will make the car act this way. Then try different droop settings starting at 2.5mm front, 2mm rear measured aboved ride height. Aluminum chassis is just another fad. I wouldn't waste my money on it. IMHO
#1788
#1789
This is not true. Granted he was in the B, Hara's winning B1 time was faster or nearly identical to Volker's A1 time, in B2, he ran a time that was good enough for a top 3 in the A.
Hayato ran an aluminum chassis as well and he was in the A Main, challenging for the lead in one of the mains too.
The aluminum chassis is not better or worse, like many people here are saying. It's just different. As to whether it is better for high or low grip is really dependent on how much flex you are willing to risk on the aluminum chassis. If you are willing to run it with less top deck screws to increase flex at the expense of some durability, it is fantastic in lower grip.
One thing is for sure, the lower cg makes a car easier to drive. It becomes more stable and predictable. It is also fantastic over corner dots.
The one issue where carbon is superior is the resistance to tweak. One hard wreck on an aluminum chassis, and it could be all she wrote.
#1790
I agree, it's not better or worse (well it could, if you have a hard hit). I'm not even sure if those guys change chassis between heats. I know for sure that Volker was using the carbon fiber chassis. But I'll leave it at that, it is just not for me.
#1792
I'll be at Mike's thursday night in Texas and Valkaria on Sunday. Carpet and asphalt.....Living it up!
#1794
Hey guys
Just wondering if anyone uses reedy 7000mah 65c Lipos in their t4. Im currently using the t4'13 and find that the lipo slightly touches the the tip of the rotor on my orion motor. I yet havent used the battery because of this. The pack is slightly puffed as which is normal apparently on these batteries? This is very annoying considering the price tag. Please let me know how you use this pack without dramas. Cheers!
#1795
just dremel the motorshaft down a little
#1796
Hey guys
or use XRAY & ARENA Pinion gear
#1797
Hey guys
You could also grind out the battery retainers a little and make sure you secure the battery just a little further out.
#1798
Hey guys
#1799
the only thing that will hold the lipo secure without moving is tape,i have used the battery stops from a tc6,using one screw and a bit if shoe goo ,itll stop it moving side ways,since i started using tape i havent had a pinion touch ,and i use schumacher or rw pinions,never even seen an xray pinion so cant compare
#1800
Hey guys
Just grind the motor shaft down so it no longer touches. I had to do it on a couple of motors.
