Speed Passion brand new Spec Racing LeMans car - The LM1
#364
lol. I have been doing 3-5 runs a day as time allows and tweaking here and there for my driving style.
I still want to raise the center shock about another 2mm at the battery brace to get it flatter. the last run last night I added a touch of toe out, ( I would guess 1 deg per side) for me, it helped the car get in the corner better.
I still have to "float" the car into the sweeper, the lower front roll center (shimming the castor blocks up) made the steering much more responsive.
We will have to see what Rob, Kevin and Rick come up with at Hot Slots today
#365
Updated:
LMP Class
Chassis: any F1 style chassis
Motor: 17.5 (Open)
Battery 2S 7.44v
Body: Speed Passion LM-A
ESC: Open
Tire: Open
Drive Ratio: 26/72
Minimum Weight: 1200g (that's grams for those who aren't sure)
LM1 (or LMPC)
Chassis: Speed Passion LM1 only
Motor: 17.5
Battery 2S 7.44v
ESC: Blinky/Sportsman
Tire: Kit Foam
Drive Ratio: 26/72
Minimum Weight 1200g
LMP Class
Motor: 17.5 (Open)
Battery 2S 7.44v
ESC: Open
Tire: Open
Drive Ratio: 26/72
LM1 (or LMPC)
Motor: 17.5
Battery 2S 7.44v
Tire: Kit Foam
Drive Ratio: 26/72
#366
LM-1 spec class
Just my 2 cents, but you may want to give people 3-4 pinion choices for gearing at different types of tracks.
We have done this with Spec175 here, everyone runs a 84T spur (64-pitch) and you can run a 44, 45, 46 or 47 tooth pinion.
Our local track just moved on-road from outside (asphalt with 90' straight) to inside carpet (about 65' straight) and it's tighter and more technical, so the smaller pinions are working better.
May I suggest 26, 28 or 30 tooth pinions (48-pitch) for different sized tracks for the LM-1?
Thanks,
-Rich
Thanks,
-Rich
#367
#368
Thanks,
-Rich
Thanks,
-Rich
#370
I ran the last changes I did yesterday against the USGT cars just to get some "race" feel for it. Much faster closing/straight speed than the GT's and about the same infield. I could have probably gone down to a 23T pinion and been ok with 21.5
#375
can come up with like the Toyota TS030 hybrid or the Lola B60/12 coupe. If not
then it will be like World GT where everybody uses the same body with different
paint jobs and liveries and can be very boring, Nevertheless it is a very pretty
car. Mine is mounted on a F104 chassis modified with a R Sector 200mm kit and
it is a very good handling kit. Just my two cents worth. Attached photo. Regards
Norman
