New XRAY X12 All new 2014 >
Like Tree1Likes
Old 05-16-2014, 04:17 PM
  #121
Any tips, tricks, or suggestions would be greatly appreciated.
TurboJuice is offline
Old 05-16-2014, 07:21 PM
  #122
Car Breaker's Avatar
Get springs of different stiffness, also you need oils of different weight for the side tube,you will need those to tune for your track, ask around about tube oil and tyre choice.
Car Breaker is offline
Old 05-25-2014, 03:04 PM
  #123
Bigz84's Avatar
Trader Rating: 24 (100%+)
Hello,
w/ the stock 76t spur, what is the largest pinion that can fit? will a 59t pinion fit? or should I get a smaller spur to get a smaller pinion in there to run 17.5 stock, blinky.
Bigz84 is offline
Old 05-25-2014, 03:48 PM
  #124
PACaSteel's Avatar
You've got a 1.9 Spur to wheel ratio. It depends on your track and your motor, but for medium asphalt I'd shoot for something in the 3.5 to 4.0 range. If that's what your looking for, start with a 40 and tune from there.
PACaSteel is offline
Old 05-25-2014, 06:37 PM
  #125
Trader Rating: 70 (100%+)
Originally Posted by Bigz84
Hello,
CRC makes a 72 that should work. Keep in mind they are 3/32" balls though. I found that regardless what spur/pinion you use, the maximum number of teeth total can be 133. Ie, 76/57, 72/61, etc. For 17.5 you should shoot for 100-110mm of rollout depending on the track/motor.
PROMODVETTE is offline
Old 05-25-2014, 10:39 PM
  #126
Here she is...
Fresh, silky buttery smooth, and ready for electronics.
Very impressed with the fit and finish.
Great manual.
Now should I do Orca/Reedy Sonic or LRP Flow/Maxzilla?
Old 05-26-2014, 07:55 AM
  #127
Bigz84's Avatar
Perfect, thanks for the info
Bigz84 is offline
Old 05-26-2014, 06:07 PM
  #128
Originally Posted by TurboJuice
Here she is...
Great manual.
Orca/maxzilla Ask at your club if the D3.5 is still legal though, if not Orca/orca!
Old 07-18-2014, 05:28 AM
  #129
ATMHOBBY's Avatar
Does anyone know where I can get an x12 2014?
ATMHOBBY is offline
Old 07-18-2014, 07:26 AM
  #130
R/C Tech Elite Member
RCBuddha's Avatar
Trader Rating: 40 (100%+)
http://www.reflexracing.net/XRAY-X12...r-_p_2073.html
RCBuddha is offline
Old 07-18-2014, 07:37 AM
  #131
SLOWINSLOWOUT's Avatar
Trader Rating: 20 (100%+)
I may be selling mine, with a bunch of spairs, and a boat load of tires. PM me if interested.
SLOWINSLOWOUT is offline
Old 07-19-2014, 06:07 PM
  #132
Bigz84's Avatar
Default top shock
I've seen the top shock mounted both ways. What are the benefits of mounting it either way, if there is? Ie top of the shock mounted towards the rear.
Bigz84 is offline
Old 07-19-2014, 08:05 PM
  #133
Hwo does people deal with slop, after running the car for few months, slops are every where in the front steering system in steering blick, upper and lower pivot ball,not even a 2 degree camber can stop coning the tyre every run, I wish xray can change it to CRC/Serpent style to prevent slop development
Old 08-08-2014, 03:31 AM
  #134
Peakki's Avatar
Some tips to get rid off slop:
To take out steering block slop:
1. Make a flat spot to kingpin
2. Drill a Small hole for 3mm pinion screw to the steering block
3. Add 3mm pinion screw to steering block and align with flat spot and tighten - this way you get the block fixed to kingpin
4. Place a lot of attention to front end smoothness when doing this mod. If the upper eyelet is wrong position, the front end binds a lot.
Use also shims to adjust downstop, because all front springs collapse.
Use metal (not those black ones, they bind) balls in lower arm and replace arms.
There is some amount of slop between upper arm hinge pin. This can me removed filling the upper arm hole with CA and then using reaming the hole again.
Hope these and a lot of patience helps
Peakki is offline
Old 08-08-2014, 03:47 AM
  #135
Not sure if it's true but i've heard that there will be a new version released, i geuss the X12 2015 version.
addicted2blue is offline
