Maintenance
Old 09-19-2013, 04:36 PM
Default Maintenance
I have a t3 '11 1/10 touring car what is the maintenance I need to do? Between races after race days over the coarse of time etc.
prorcguy is offline
Old 09-19-2013, 05:39 PM
F. Mendoza's Avatar
Trader Rating: 79 (100%+)
Clean and rebuild shocks, axles and relube bearings every other race day. Replace belts as needed. Dry bearings slow a car. Dry axles cause binding and irreversible damage Clean pulleys often. Check for loose screws every time you can.
Xray is a great TC. That is what I've run for the last 7 years. No regrets what do ever. .
F. Mendoza is offline
Old 09-19-2013, 06:18 PM
valk's Avatar
Trader Rating: 13 (100%+)
xray shocks do not need to be rebuilt that often at all. you can probably go half the season or more on a fresh build assuming you dont change the oil in them and build them properly.
during a race day, assuming you havent had a massive accident, its just a matter of blowing the crap off the car, making sure all the axles and belts move freely and there isnt any binding. make sure all your screws are still there and are tight. if you have a bad accident that involved a broken suspension arm or top deck or similar, it might be nessisary to strip the car when you get home to check for alignment and stuff as suspension holders and bulkheads can get out of alignment.
after a race day, i might check some of the bearings to make sure they move well but ill usually just back the motor off its mesh and I can tell right away by how the belts move. checking cvd pins should be normal as they tiny setscrews in there often come loose and start to mess up the steering block/uprights unless they are bearing captured.
really, id just start watching the habbits of people who win races at your track, and copy them for the most part.
otherwise, most of the stuff on these cars is pretty common sense. if its broken, replace, bindy, replace ect.
Jilles Groskamp posted a great series of youtube videos on how to properly build a touring car, at least his touring car. Schumacher has also posted some that I found useful for building and maintaining shocks.
valk is offline
Old 09-20-2013, 07:44 PM
Thanks for the help.
prorcguy is offline
