how tight?
Old 09-18-2013, 06:37 PM
Default how tight?
yes im newbie
but how tight should i have my front & rear belts? 17.5 binky
both really loose? im running a solid front axle gear dif.
thanks for help
TeamThibault is offline
Old 09-18-2013, 07:44 PM
Jerz616's Avatar
Trader Rating: 49 (100%+)
[QUOTE=TeamThibault;12555985]yes im newbie
thanks for help[/QUOTE
Typically I would run the front belt just a notch or so tighter then the rear. I run my xray one notch past center towards the center of the car. My rear belt is just a but looser then the front.
Jerz616 is offline
Old 09-18-2013, 08:53 PM
ThePanda's Avatar
Trader Rating: 68 (100%+)
in 17.5 you really beed as much power as you can so run them loose. not falling off, not skipping, but not super tight either
ThePanda is offline
Old 09-18-2013, 08:59 PM
valk's Avatar
Trader Rating: 13 (100%+)
Manual setting is ideal for 17.5. any looser and the belt can skip during braking or easily get chunks of crap in the pullies. if your belt is flapping around at full steering lock, you might go one notch tighter.
valk is offline
