TC4 questions
Old 09-11-2013, 08:01 AM
  #31
Donn's Avatar
For any of you that are changing from the plastic outdrives to the steel, you need to note that they build differently. Here are the links for both types of builds.
Steel
http://www.teamassociated.com/pdf/ca.../3918_inst.pdf
Plastic
http://www.teamassociated.com/pdf/ca..._outdrives.PDF
Thought you should know to make sure you get the correct parts.
When you get the steel outdrives, be sure to also purchase:
Diff rings #6579
T-nut #6579
Donn is offline
Old 09-11-2013, 08:19 AM
  #32
DarthRacer's Avatar
Do you guys know where to get good instructions on converting a TC4 diff to a slipper spool? I would like to experiment on my backup car.
DarthRacer is offline
Old 09-11-2013, 08:40 AM
  #33
get some 31173 TC5 slipper pads, sand them down lightly on 1k sandpaper, asseble the diff without any balls, use locktite on the bolt.
install the diff and check if you have side play in the case, if not sand the pads a little more.
check page 5 for assembly
http://www.teamassociated.com/pdf/ca...c5r_manual.pdf
This will only work with steel outdrives
Rojna is offline
Old 09-11-2013, 09:16 AM
  #34
Too much of a hassle to build a slipper spool as a backup. Just get a tc4 spool/lcd and your done..... So much trouble not to make the Amain.....wow.....
bertrandsv87 is offline
Old 09-11-2013, 09:20 AM
  #35
Also, when the pads wear out , the bits will lodge themselves between the pinion and diff ring gear....nice.... Lots of folks love to make it difficult !!!
Old 09-11-2013, 09:38 AM
  #36
I have built slipper spools with both 3912 and the lightweight 31062 outdrives, 3912 does have more surface area for the pad but both work great, I like the lighter ones for the weight savings.
Rojna is offline
Old 09-11-2013, 11:11 AM
  #37
DarthRacer's Avatar
Geez dude, I said I wanted to test a slipper spool in my backup car since it has a front diff. I already have a car with a front spool that is the primary. ??
Old 09-11-2013, 02:50 PM
  #38
Well, you will see the difference....
Old 09-11-2013, 03:26 PM
  #39
DARKSIDE's Avatar
whats the issue...ppl are looking for help with the AE TC4, and its seems like drama ?...if anybody needs help with the TC4, please pm me or Brian S....who probably knows way more than he should about the chassis and setup...
Battman
Stop the drama....
DARKSIDE is offline
Old 09-11-2013, 03:38 PM
  #40
Different point of view is not drama..... We all learn from it.....
Old 09-11-2013, 03:47 PM
  #41
DARKSIDE's Avatar
Okay
DARKSIDE is offline
