Lipo has no balance plug?
Hey guys I just got a 7.4 5000mah venom lipo off eBay. Well it came and it has no balance plug it is a hard case lipo an it looks like just inside there are tow wires where one may have been. Can anyone advise me on what. Can I open the hard case and solder a new one on? Thanks in advance.
Looks like ill have to. I haven't programmed my esc for lipo cut off and ill have no other way to monitor low voltage. Not to mention my onyx 235 will not charge unless a balance connector is attached.
Correct on the 235. It's a safety feature and a good one at that. My personal opinion is you should balance each time. It doesn't cost anything to do it. Adding a balance plug is not a huge deal. I had a receiver pack that did not have one. Just opened it up, took my time and soldered on a plug from an old battery. Worked like a champ.
Does it have a small hole between the 2 bullet connector holes? Some LiPo packs use a small bullet connector for the balance plug.
For the OP, here is a pic of a bullet venom pack and the wiring harness for it:
http://blaisracingservices.com/image...m_5000_60C.jpg
No it does not have a bullet connector. When I add the plug what do I solder to a + and - to each cell? Also any tips on opening this case I tried a small screwdriver but that didn't work. Should I plan on getting a new case afterwords. (I forgot to mention its a hard case pack)
Well I have n
We'll I have no other lipos but I found the plugs on eBay so I'm getting one from there. Anybody have tips on opening the case to this. It almost seems like a one piece case.
