Tekin RS GEN2 SPEC
#31
Should the RS Spec perform as well as the RS Gen2 in blinky?
I'm looking at using it for oval racing actually.
#32
Moderator
Yeah if you are using motors in the spec limit of the RS Spec they are virtually the same. The RS has a bit more beefed up gear in it (Fets) to handle more motors, boost/timing.
The spec has the same basic stuff in it, just lighter since the motor window is smaller and the software only does blinky.
#33
Sorry to bring up a dead thread but i was wanting a question answered and cant seem to find it. When you plug this esc up to a hotwire can you program it to run on 1s mode for 12th scale? I know you can do that with the RS Gen 2 mod esc. The specs are the same basically so i don't see why not?
#34
If I'm getting it right, I should use Hotwire to put it in 1s mode, keep the red wire in the servo plug since the ESC need 6V from a RX pack to get the software running properly and put the switch ''on'' in order to monitor voltage.
#35
yes works exactly the same, you will need a booster or rec pack.
#36
How has the rs gen2 spec esc performing lately? Going to be using one in 17.5t touring blinky soon..
