*NEW* WILDFIRE D06 Touring Car from VBC RACING
#1172
#1173
I've been searching for the answer, apologies if this has already been asked. I guess I have myself a little confused
In reference to this chart:
What is the difference between the suspension mounts E and F? I see from the chart on the front-front we can use E10, E15 but then F00, F05, F10. Why not use E20, E25, E30?
I guess this chart has me confused as it appears fitting a wider rear-rear block will increase rear toe in but fitting a wider rear-front block will also increase rear toe in :S It seems the chart must be wrong?
I have seen solid P blocks available for front-rear instead of split blocks. If I want to use a solid block on the rear-front which type do I use E, F or P? For the rear-front block which one would be the same as C0?
TIA to anyone who can help with my confusion
#1174
Raceberry has some new Shock towers for the D06 to run longer shocks.
http://www.redrc.net/2014/06/raceber...ys/#more-83104
#1175
F blocks widen the front end of the car
I guess this chart has me confused as it appears fitting a wider rear-rear block will increase rear toe in but fitting a wider rear-front block will also increase rear toe in :S It seems the chart must be wrong? The C blocks (Other than C00) for the rear can both widen or narrow the front rear end of the car. X and Y blocks can be swapped. These blocks can also be used at the front rear to provide the same functionality.
I have seen solid P blocks available for front-rear instead of split blocks. If I want to use a solid block on the rear-front which type do I use E, F or P? For the rear-front block which one would be the same as C0? I don't believe that the solid suspension mounts would work at the rear of the car as they would interfere with the rear belt.
#1176
Thanks Gridworks but I'm still a bit confused...
What is the difference between F and E blocks?
You said F blocks make the front of the car wider but E20, E25, E30 must also make the front of the car wider than using E15?
I guess I am struggling to see why there is a need for a different FF block when RR blocks can be used (at least up to a point, E15). Why can E blocks only be used on FF up to E15 then have to use F blocks? Perhaps they are the same as some F blocks just marked differently to make it easier to determine the settings?
I understand C blocks can be flipped to widen or narrow the car so I guess the error in the chart is that the narrow -> wide label for rear C blocks should be reversed to wide -> narrow. At least that way it makes sense to me xD
I guess I will have to live without a solid RF block if they don't fit, no worries =]
#1177
I would imagine that the reasoning in your last sentence is probably accurate.
#1178
Ok thanks again. That makes sense now. I guess when I have the chassis, some blocks and calipers to hand I can make complete sense of it. Can't wait =]
#1179
#1180
What diameter of the balls on the steering knuckle? I have a cracked Ballcup on one and have to find a replacement locally (non VBC) till I do my Gridworks order.
#1181
#1182
They're 5.5mm. I have used a Top cars rod end in a bind, it fits a little tight so you have to free it up with some pliers, but it gets you by.
#1183
#1184
We are also awaiting the parts for our stabilizer modification and just parts in general. We are going to be even more swamped very soon!
