Holes in the wheel under the insert >
Old 06-12-2005, 02:59 AM
Default Holes in the wheel under the insert
Some wheels has holes and some does not. Some are small (0,3mm) and some are bigger (2mm). If your new wheels doesn't have holes do you drill them?
Tral is offline
Old 06-12-2005, 03:10 AM
Matt Howard's Avatar
If your rims don't have any holes in them then absolutely drill some. Your tires will be like balloons if you don't put a vent hole in the rim.
Matt Howard is offline
