Hot Bodies D413 1/10 4WD Buggy >
Like Tree66Likes
Old 12-18-2015, 12:23 PM
  #10291
rcgod's Avatar
Trader Rating: 33 (100%+)
Originally Posted by nitro2be
that's it. I remember now changing to 3 and 2 because my 1 was so worn I put 2's in because new and did not think little more kick up would have that much effect. I now im thinking about it my mbx7r eco starting doing same thing (front wheelies) under hard braking and I just increased kick up because I noticed front diving so much. Learn something new everyday!!
what rear sway bar do you use? I run copper and copper front and rear and have like it so much, but car can always be better.
Fyi I have talk to an older retired pro driver about 12 caster and 5 steering and said would make car to lazy and easy to drive. said 5 steering and 10 caster would be perfect for most tracks.
I run copper rear and no front sway bar.
I expect more caster to do what you said but sometimes things work in reverse depending on geometry and other factors.
rcgod is offline
Old 12-21-2015, 07:43 PM
  #10292
Any wing recommendations ? Looking at pro-line trifecta pre cut or stock HPI wing. Only thing I didn't like about the stock wing is the wing buttons don't sit flat on it.
I did see the heavy duty molded wings in the really old posts but want to stick to the lexan wings.
Jason84 is offline
Old 12-21-2015, 07:51 PM
  #10293
nitro2be's Avatar
The trifecta is a great wing I have it on my rb6 and use the sworks 104 wing on my d413 and my buddy uses the sworks on his b44 and we both agree best 8 bucks ever spent.
nitro2be is offline
Old 12-21-2015, 08:14 PM
  #10294
Is S104 wing molded plastic or lexan ? And do you use exotek wing buttons and mounts ?
Nevermind looked it up it is molded
Jason84 is offline
Old 12-21-2015, 08:19 PM
  #10295
R1Joel's Avatar
Don't mind the stock wing. Has be solid for me. Pre-cut Proline Trifecta is great though.
R1Joel is offline
Old 12-21-2015, 08:43 PM
  #10296
Do you have the exotek wing mounts though ? The buttons don't sit flat on the wing unless you run it in low position.
Jason84 is offline
Old 12-21-2015, 09:13 PM
  #10297
nitro2be's Avatar
nope pins.
nitro2be is offline
Old 12-22-2015, 12:30 AM
  #10298
ajj
ajj's Avatar
Trader Rating: 18 (100%+)
Does anyone know the availability of the aluminium shock standoffs (pn #115136), is there anywhere that stocks them? One of mine is badly bent.
ajj is offline
Old 12-22-2015, 12:45 AM
  #10299
ajj
ajj's Avatar
The Proline Trifecta can't be used in the low position with the Exotek wing mounts and buttons. The buttons interfere with the profile of the wing.
ajj is offline
Old 12-22-2015, 04:24 AM
  #10300
Cant find them anywhere. So i use the ones from the d815 in front. Much beefier and puts the shocks a couple of mm forward. #67202
boggiii is offline
Old 12-23-2015, 07:02 PM
  #10301
ajj
ajj's Avatar
Thanks I'll look into getting some.
ajj is offline
Old 12-23-2015, 09:14 PM
  #10302
nitro2be's Avatar
look what I did overkill but i like it. thanks for the advice.
Attached Thumbnails Hot Bodies D413 1/10 4WD Buggy-20151223_210223_resized.jpg
nitro2be is offline
Old 12-24-2015, 02:54 AM
  #10303
Yeah its a bit overkill.... but i think they are better. They also stop the front to rear movement of the shocks, so i might put them on the rear to. There is way to much movement after a couple of runs with the ones supplied with the alu shock caps.
boggiii is offline
Old 12-24-2015, 04:41 AM
  #10304
anythinggas's Avatar
Trader Rating: 21 (100%+)
Need a little help, does anybody know what the part number is for just the pins that hold the hexes on.
anythinggas is offline
Old 12-24-2015, 10:39 AM
  #10305
nitro2be's Avatar
# 112744
nitro2be is offline
