Hot Bodies D413 1/10 4WD Buggy >
Like Tree66Likes
Old 08-21-2015, 07:22 AM
  #9736
Team Tekin
yzracer758's Avatar
Trader Rating: 18 (100%+)
Originally Posted by RENOV8R
I'm running a 6.5 Tekin and no fan. nevr gets above 160 degrees
Ditto!
yzracer758 is offline
Old 08-21-2015, 07:23 AM
  #9737
wittyname's Avatar
Originally Posted by yzracer758
Ditto!
20, 21 tooth pinion ?
Never mind.... Front page says 23 ish
wittyname is offline
Old 08-21-2015, 12:09 PM
  #9738
nitro2be's Avatar
I fixed it.
nitro2be is offline
Old 08-21-2015, 12:57 PM
  #9739
kenny lutz's Avatar
Trader Rating: 38 (100%+)
i have started to find what im looking for from the car i missed the shock package for how blown out the track is just i made some changes as the car would get upset a little bit through the blown out parts. im going to try 40 front with 1.5s and 1.7 rear with 32.5 and see how it does but i think that will fix the issue.
kenny lutz is offline
Old 08-21-2015, 11:16 PM
  #9740
nitro2be's Avatar
I run rcshox 40 1.6 front and 32.5 1.7 rear with red front and gold or silver can't tell the color rear springs. Works perfect in the ruff stuff.
nitro2be is offline
Old 08-21-2015, 11:33 PM
  #9741
Originally Posted by SeanKewley
Building the kit from new was a very enjoyable experience for me. If you are someone that enjoys building kits, I would recommend buying the buggy as a kit. If you don't care about building, then I'm sure you'll find a reasonable deal on a used roller in the next few months.
Do you think a new car is coming?
MadRiderSD is offline
Old 08-22-2015, 02:38 AM
  #9742
R1Joel's Avatar
Took my D413 for it's maiden voyage today. Wow what a car. Handles precisely even on a loose track.
R1Joel is offline
Old 08-22-2015, 05:33 AM
  #9743
Crazy Carl's Avatar
Trader Rating: 7 (89%+)
Anyone running on med. bite, what diff oils are you using?
Crazy Carl is offline
Old 08-22-2015, 09:21 AM
  #9744
nitro2be's Avatar
Yep, very nice car. I can even be in the air almost upside down and without much wheel it still lands on it wheels. Amazing.
nitro2be is offline
Old 08-22-2015, 10:42 AM
  #9745
Trader Rating: 27 (100%+)
I took the plunge and bought a kit with all the trimmings! Amain probably knows my address by heart this week. Looking through some of this thread from a year ago, i saw that spur gears were stripping. Is this still an issue or will the exoteck spur and mounting plate i ordered help this? Also, do people prefer specific brand of pinion gear for this car? I'll be running a 6.5 orion. I look forward to many days of fun with this car! I hope it helps my 1/8 nitro driving in the process
Brett C is offline
Old 08-22-2015, 11:29 AM
  #9746
kenny lutz's Avatar
I'm running 7/100/3 that's what I found was the best.
Old 08-22-2015, 01:09 PM
  #9747
nitro2be's Avatar
+1 out door med. 7/100/3
nitro2be is offline
Old 08-22-2015, 01:11 PM
  #9748
nitro2be's Avatar
I bought mine 12/2014 and run almost every week and still same stock spur. I run Robinson steel gears. No problems and kinda quite
nitro2be is offline
Old 08-22-2015, 03:28 PM
  #9749
Crazy Carl's Avatar
Should had said it before I'm indoors. Still the same ?
Old 08-22-2015, 04:42 PM
  #9750
13Maschine's Avatar
Thanks! Just ordered the hubs and bushings. I've been using the X-Ray bushings, we'll see if these are as good
Keep us posted! I've been looking at the Xray bushings so I'm curious to hear your comparison. Although I'm tempted to just order a set of Exoteks so they arrive as soon as I return from Seattle.
13Maschine is offline
