Hot Bodies D413 1/10 4WD Buggy >
Like Tree66Likes
Old 07-12-2015, 12:47 PM
  #9526
nmdesertracer's Avatar
Trader Rating: 59 (100%+)
Thumbs up
The wing looks good!
nmdesertracer is offline
Old 07-15-2015, 10:48 AM
  #9527
Mounted a fan in my d413 today, Got a big race coming up this weekend and i might need to squeeze more out of my 10.5 setup. I mounted it with one screw right to the motor plate mount. Its rock solid. Hopefully the non factory bodies allow more room to move the fan over in the future. Here are a few pics.
Apexracing is offline
Old 07-15-2015, 12:15 PM
  #9528
VinMoto's Avatar
Has anybody tried to run saddle pack config. Im trying to do so now and I cant get my motor to fit. Any help would be appreciated. Thanks
VinMoto is offline
Old 07-15-2015, 12:18 PM
  #9529
VinMoto's Avatar
Tried Tekin and Trinity motors both are too long
VinMoto is offline
  #9530
VinMoto's Avatar
I only own saddle packs, id like to run them
VinMoto is offline
Old 07-15-2015, 12:29 PM
  #9531
Team Tekin
yzracer758's Avatar
Trader Rating: 18 (100%+)
You will have to dremel down the steering post in order to get the clearance for the motor to fit. It's currently the only option for running it with saddle packs with most all the motors.
yzracer758 is offline
Old 07-15-2015, 12:32 PM
  #9532
VinMoto's Avatar
WOW, wish i knew that before I purchased this, thanks YZ racer
VinMoto is offline
Old 07-15-2015, 12:47 PM
  #9533
RENOV8R's Avatar
It's funny the only motor found that fit in saddle pack config are made by HB. Better to go shorty setup anyway, car handles so much nicer
RENOV8R is offline
Old 07-15-2015, 01:16 PM
  #9534
VinMoto's Avatar
Youve tried both set ups? Please explain. I would think saddle packs add more balance in the chassis. Please sell me on why I should reconfigure and buy new batteries? Im ready to take my new servo out and sell it.
VinMoto is offline
Old 07-15-2015, 02:22 PM
  #9535
VinMoto's Avatar
Anyone have any luck with Avid Chassis or Schelle stretch chassis??
VinMoto is offline
Old 07-15-2015, 02:52 PM
  #9536
Dal
Dal's Avatar
Im running saddles, with LRP motor, it fits in , just, I had to take note of the sensor plug, as it was hitting the steering post, but once on the correct angle, all is good
Dal is offline
Old 07-15-2015, 04:13 PM
  #9537
VinMoto's Avatar
Thanks, Im gonna have to shave the post slightly, remove it then install the motor. Once its in ill try and reinstall the post. hope it works. Im curious to see handling and lap time differences between both set ups
VinMoto is offline
Old 07-15-2015, 04:15 PM
  #9538
STLNLST's Avatar
Trader Rating: 32 (100%+)
Running the Schelle aluminum chassis with great success. Car is very stable.
STLNLST is offline
Old 07-15-2015, 04:50 PM
  #9539
Suspended
Look at the way the car is layed out, and use your brain. It's obvious that the car will be way more balanced with a shorty pack. With saddles you have equal battery weight on both sides, but the motor and ESC in the front right are going to weigh a lot more than a servo and receiver.
A shorty pack weighs about the same as a motor, and a servo weighs about the same as an ESC, and receivers are usually very light. The saddle pack thing was really to conform to a rule that is no longer enforced. You just spent a bunch of money on a new kit, spend the $40 for the right battery.
Mantis Toboggan is offline
Old 07-15-2015, 05:27 PM
  #9540
nitro2be's Avatar
+1
nitro2be is offline
