Hot Bodies D413 1/10 4WD Buggy >
Like Tree66Likes
Old 04-30-2015, 06:32 PM
  #9031
nmdesertracer's Avatar
Trader Rating: 59 (100%+)
Thumbs up
Originally Posted by rangerjkb
I had a chance to run & race the car for the first time...it's absolutely a fantastic racing platform (TQ, Win and 4/100th sec off the tracks fast lap record).Thanks for providing us such a good 4WD Buggy HB!
Time to move out of Novice class!! J/K congrats
nmdesertracer is offline
Old 04-30-2015, 06:35 PM
  #9032
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Whats a good run of springs to have on hand? out door clay track blue groove - how are most of you guys running your shocks with bladder or with out?
BlackStarRacing is offline
Old 04-30-2015, 07:03 PM
  #9033
My track is higher grip clay but with big steep jumps. The stock set up was a bit soft. I went to 40 f/ 35 r in oil and bumped up to Associated blue springs up front (HB fronts were out of stock on amain) which are VERY close to the next step up on HB spring rate equivalents and then one bump up on rear springs. So far I like it!
dblhelx is offline
Old 04-30-2015, 07:21 PM
  #9034
thanks for the starting points
Old 05-01-2015, 03:31 AM
  #9035
egobrkr's Avatar
Trader Rating: 29 (100%+)
I use bladders with 450 cst front and 350cst rear with 4 hole 1.2 pistons that came with the kit. I'm still using the stock springs.
egobrkr is offline
Old 05-01-2015, 06:16 AM
  #9036
I use the bladders, too. Just put in VRP pistons, as well. 1.6/1.7.
dblhelx is offline
Old 05-01-2015, 06:35 AM
  #9037
Im runnin bladder less but what i did was what we did with the losi 8 i cut the middle of the bladder out....
Ill be getting some laps in this weekend so ill come with some feedback!
Old 05-01-2015, 07:48 AM
  #9038
egobrkr's Avatar
That is called emulsion. I would suggest going up in oil weight from what you usually use. I like bladder a little better because they feel more consistent and the oil to me breaks down faster with emulsion style.
egobrkr is offline
Old 05-01-2015, 07:55 AM
  #9039
Trader Rating: 49 (98%+)
What would you suggest going up to? I run the emulsion setup. I have the stock size pistons. I am running losi 40wt in the front and 35 wt in the rear.
wheres_yogi is online now
Old 05-01-2015, 08:54 AM
  #9040
egobrkr's Avatar
In my experience with various kits that I used emulsion on I would need to go up 5wt-10wt from what I used with bladders. You may like 40 wt and 35wt but I found the oil I used with bladders to be soft when I switched to emulsion.
egobrkr is offline
Old 05-01-2015, 10:23 AM
  #9041
mvrk28's Avatar
I run 40/30 AE with VRP 1.6 in my car and it's dialed.
mvrk28 is offline
Old 05-01-2015, 10:36 AM
  #9042
egobrkr's Avatar
This is why I only suggested it with my experience. Different track conditions, drive style, traction ect... will dictate what will work for you.
egobrkr is offline
Old 05-01-2015, 12:45 PM
  #9043
much appreciated info, better to have it and know how to begin to adjust it. then to not know where to begin?
Old 05-01-2015, 05:06 PM
  #9044
STLNLST's Avatar
Trader Rating: 32 (100%+)
Got my new Factory RC goodies to compliment this sexy Schelle aluminum chassis. All I can say is OMG this feels waaaaa better than my Yok ever did. In the pic of the Factory RC pieces I flipped the center piece to try and show you the angled cuts it has underneath. The battery mount is helpful for those of us that have fans mounted directly to the battery and we ask a friend to put your car down once it's done charging.
Attached Thumbnails Hot Bodies D413 1/10 4WD Buggy-20150501_165735.jpg   Hot Bodies D413 1/10 4WD Buggy-20150501_165759.jpg
STLNLST is offline
Old 05-02-2015, 04:07 AM
  #9045
rangerjkb's Avatar
Trader Rating: 45 (100%+)
yeah, no kidding, lol! Very glad the car worked so well and is fun to drive, looking forward to having some great races in the future with it
rangerjkb is offline
