Hot Bodies D413 1/10 4WD Buggy >
Like Tree66Likes
Old 02-13-2015, 04:44 PM
  #7711
jwood7's Avatar
Originally Posted by RENOV8R
For the cost involved, why not just install the RC Shox pistons that are made for the shocks and be done with it. 1.6 2-hole front & 1.7 2-hole rear seems to be a good setup
i was disapointed with the rc shox pistons. too much blow by and movement in the shock body. i was very hesitant to try the vrp pistons but i have to say they work awesome.
jwood7 is offline
Old 02-13-2015, 07:53 PM
  #7712
ISH
ISH's Avatar
i bought the Rc show steering bar and it works great and did take up all the slop that the stock one has. i could not pull the trigger on the piston tho. $20 with shipping didn't make sense to me. so i drilled out the ones that the kit comes with 2x1.6 all around.
ISH is offline
Old 02-14-2015, 04:21 AM
  #7713
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
I'm going to assume you run the standard VRPs and not the tapered pistons at Timewarp?
Yeti AS3 is offline
Old 02-14-2015, 06:29 AM
  #7714
Default Aluminum chassis
For people using the avid aluminum chassis on carpet, how does it perform over the stock carbon chassis?
hbae3052 is offline
Old 02-14-2015, 01:26 PM
  #7715
TORQUE ROD's Avatar
Default Upper links ?
Can anybody explain the difference between a longer link vs a shorty link
and where to use it?
TORQUE ROD is offline
Old 02-14-2015, 01:35 PM
  #7716
Team Tekin
yzracer758's Avatar
Trader Rating: 18 (100%+)
Longer links calm the car down. Shorter link will make the car react and change direction faster.
yzracer758 is offline
Old 02-14-2015, 02:26 PM
  #7717
Yeti AS3's Avatar
Few reads for ya...
http://users.telenet.be/elvo/
http://home.scarlet.be/~be067749/58/bug/print.htm
Yeti AS3 is offline
Old 02-14-2015, 04:54 PM
  #7718
Trader Rating: 23 (100%+)
Originally Posted by snwchris
You can use the Composite B5 caps and need the composite B5 standoffs for them.
As for Aluminum, the only option beside the HB ones are using the Serpent SRX Caps, Standoffs and bushings, which add up quickly.
Have you used the serpent caps?
bmcallister is offline
Old 02-14-2015, 08:18 PM
  #7719
jwood7's Avatar
yeah the standard. been running them at trackside too
jwood7 is offline
Old 02-14-2015, 08:23 PM
  #7720
jwood7's Avatar
i found a set of shims from ae that works to remove slop from the ackerman and the spindles for around $2. i can post a part number tomorrow
jwood7 is offline
Old 02-15-2015, 02:51 AM
  #7721
Great
ColourGhost is offline
Old 02-15-2015, 04:18 AM
  #7722
Looking for a carpet low/low-medium (more low than medium) bite diff setup. Running 15/60/4 now. This car is so difficult to drive compared to the XB4.
My shocks still build up rebound after only 4 ours of training. I soak my Kyosho x-rings in oil 24 ours before installing, and use green slime and all. ZX6 owners say they never try that. These shocks feel really great when fresh built, but they dont seem to last that long. I know i can just let the air out, but i dont wanna do it every second hour. Any of you guys experience the same ?? Really consider changing shocks. If i can find some long shaft eyelets i try the Kyosho's.
Old 02-15-2015, 07:04 AM
  #7723
I would try 10, 100, 5 diffs
turtle189 is offline
Old 02-15-2015, 08:16 AM
  #7724
nitro2be's Avatar
Same exact thing for me.rebound.
nitro2be is offline
Old 02-15-2015, 09:23 AM
  #7725
mvrk28's Avatar
Mine have been great so far with x rings and green slime, 2 days of running and no problems.
mvrk28 is offline
