Hot Bodies D413 1/10 4WD Buggy
#7336
i run the inner shock hole on the rear arm. wondering if theres any difference using the optional c tower? what effects does it have? thanks
#7339
#7341
Not sure anyone else has bought or seen these but I just ordered a set.
http://www.ebay.com/itm/HB-D413-Grap...:X:AAQ:US:1123
At less than 1/2 the price of the HB ones takes the sting off buying a set to try.
Will post first impressions when I get them, should be a week or two.
#7342
Ordered up some Kyosho Grooved O-Rings for my shocks when I start the build, can somebody confirm they will work?
KYOORG03XR Kyosho P3 Grooved Low Friction Shock O-Ring (8)
http://www.amain.com/kyosho-p3-groov...ring-8/p151059
#7343
#7344
R/C Tech Elite Member
Increasing camber isn't going to result in more traction rolling. On carpet, I have seen a lot of people tire glue an even coat around the outside side wall of the front tires. This allows the tire to slide at extremes (through long sweepers especially) instead of completely folding over and jacking the car over. Thicker sway bars are going to plant the outside tire quicker in a corner. You could be folding the front tire over right away. You also want to run FIRM foams on carpet.
Might play around with my tires some but not sure. Our track gets setup before the races and is torn down after so there isn't much opportunity to practice or tune.
#7345
the c tower is a must imo if u run the lower hole on the rear arm.
#7346
does anyone know how you mount your wing mid height?
#7347
#7348
#7349
#7350
Has anyone used the RCShox ackerman bar? Ordered one hoping to reduce some steering slop.
