Hot Bodies D413 1/10 4WD Buggy >
Like Tree66Likes
Old 01-20-2015, 07:50 AM
  #7126
MasiisaM's Avatar
Originally Posted by khj94704
I guess I find CF weave sexier than bright anodized aluminum.
Are the wing mounts prone to breakage? I was tempted to machine something like that out of scrap delrin just so that I could avoid using clips on the wings but concluded that something rigid would just lead to more wing damage/tears in crashes, and I foresee a lot of crashes in my future.
I think the only alloy upgrades i'm looking forward to are clamping wheel hexes. Anyone make those yet? I thought the cheap 4mm integy ones I had were going to fit but their drive pins are too thick for the spindle and the stock ones are too long for the integy hexes, maybe I'll just grind those down enough to fit. I'm fairly sure some axial hexes I have would fit in the back with similarly minor modifications but I just put a dab of shoe goo on both front and rear for now and called it a day.
I havent broken a wing mount yet...and haven't seen anyone else have an issue. I think any wing is going to tear no mater what you do.. I picked up a trifecta wing from proline and its built pretty tough. It's lasted quite a bit longer than the other wings i was using.
Havent seen any clamping hexes yet...im sure someone will make them. I just used a dab of black grease and they have stayed put so far.
MasiisaM is offline
Old 01-20-2015, 08:49 AM
  #7127
kdeleon's Avatar
Since we are talking about spurs, I don't even remember the last time someone reported a stripped spur. It has been a while. I think the only things that have been reported recently were shock shaft and front tower. But even those are few and far between. It is nice to have such a durable car.
As for me, I think that I have only replaced front arms. Not that they broke but they started to bend funny prior to me gluing in the inserts. So I replaced them with new ones that have glued in inserts. Those are starting to bend too but they work fine.
kdeleon is offline
Old 01-20-2015, 08:55 AM
  #7128
Tech Prophet
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
yeah, the arms will get replace, not from breakage, but from wear. The plastics on the car are not the stiffest, but that is part of the reason it does not break.
Wildcat1971 is offline
Old 01-20-2015, 09:05 AM
  #7129
kdeleon's Avatar
But I think I prefer it that way. I can change the parts when I want to (usually back at home when I have time). And yet the worn parts never stop me from finishing the race.
kdeleon is offline
Old 01-20-2015, 09:07 AM
  #7130
Tech Prophet
yep. I concur. That is the big thing I love about this car. The confidence to finish the race.
Old 01-20-2015, 09:14 AM
  #7131
slakr's Avatar
Trader Rating: 36 (100%+)
I have had a shock cap pop off of the mount twice. Changed it out with new of the same part. Have had the HB aluminum ones on backorder for awhile now.
slakr is offline
Old 01-20-2015, 09:16 AM
  #7132
Tech Prophet
I had the caps pop off a few times, but then nothing. They have stayed on for a while now. I tried the AE caps, but didnt like it.
Old 01-20-2015, 09:19 AM
  #7133
slakr's Avatar
Ya, I bought a couple of packages of the stock units. I will just replace them as needed until the backorder for my HB aluminum caps get in.
slakr is offline
Old 01-20-2015, 09:23 AM
  #7134
jhautz's Avatar
Trader Rating: 86 (100%+)
I have a set of arms with glued carbon inserts. Anyone know of an easy way to get the inserts out once they are glued? Those things are in there good . I'm thinking I want to go back to the unglued carbon inserts. it seems my only option is side cutters and a Dremmel to cut and grind the old arms off of the carbon inserts and then put the inserts in new arms. Definitely don't want to buy another set of $40 carbon inserts.
Just wondering if anyone knows of an easier way. I was thinking I might try CA remover to see if that let's me break them loose, but I'm afraid the chemical remover may attack the resin binder in the CF.
jhautz is offline
Old 01-20-2015, 09:24 AM
  #7135
MasiisaM's Avatar
Once for me...it's not too big of a deal but look forward to the new caps anyway.
Same here..went onto tower the day the caps were listed and threw them on backorder. Tower says "Late Jan" so well see what happens at the end of the month.
On a different note: Funny thing happened on my last run...i actually lost the battery holder and the two thumb nuts that hold it down. I know I tightened the thumb nuts down...just weird. After a good 15 min of looking on the track..they came up MIA. Lame $35 mistake. to keep that from happing again i threw just a tad of blue lock tight on the threads to slow down the thumbs nuts if that happens again.
MasiisaM is offline
Old 01-20-2015, 09:29 AM
  #7136
Tech Prophet
thumb screws annoy me. I would rather use a body clip, imo. Thumb screws just take too long to swap out packs.
Old 01-20-2015, 10:58 AM
  #7137
gticlay's Avatar
Trader Rating: 14 (100%+)
That shouldn't happen. The matrix in carbon composites are pretty tough once they have cross linked.
gticlay is offline
Old 01-20-2015, 11:12 AM
  #7138
RENOV8R's Avatar
What about acetone, the same procedure as removing tires from rims?
RENOV8R is offline
Old 01-20-2015, 11:14 AM
  #7139
Trader Rating: 149 (100%+)
i was thinking of the same thing. i usually bake my tires. not sure if that would work for the carbon fiber though
skyline1015 is offline
Old 01-20-2015, 11:18 AM
  #7140
Tech Prophet
If you have an old broke CF part, toss it in acetone for a while and see what happens. I am sure the acetone will remove the inserts, just need to see what it it will do to CF.
